No boost..
Old Feb 7, 2007 | 04:48 PM
Boostedb20EH2's Avatar
Default No boost..
As i was getting on a free way ramp tonight i took the car up to redline, went to shift again and i wasnt getting any boost. I thought maybe it was just a safe gaurd or something. But my car sucks in air as normal, its just not letting out any positive boost at all. It goes up to 0 psi and stays there when i floor it. I searched, but can not find a similar problem on honda-tech. My set up is listed below if someone can please give me some things to check for it would be greatly appreciated.
Old Feb 7, 2007 | 04:59 PM
Archidictus's Avatar
Unceasing Measure
Default Re: No boost.. (Boostedb20EH2)
...did you check your charge pipes?
Old Feb 7, 2007 | 05:00 PM
95dc2teg's Avatar
Default Re: No boost.. (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">...did you check your charge pipes?</TD></TR></TABLE>
Old Feb 7, 2007 | 05:04 PM
Default Re: No boost.. (95dc2teg)
Yes, In the process
Old Feb 7, 2007 | 05:05 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, In the process </TD></TR></TABLE>
I know it's cold as **** outside, but did you really make this thread before you checked for charge pipe disconnects? Come on, man...
Old Feb 7, 2007 | 05:07 PM
Im in a heated garage now,and yes i just checked them.
Old Feb 7, 2007 | 05:13 PM
Also.. I said its putting out 0 psi.
Old Feb 7, 2007 | 05:23 PM
boosted_EM1's Avatar
up
Old Feb 7, 2007 | 05:26 PM
coneheadsracing's Avatar
Default Re: No boost.. (00 Em1)
wastegate? Make sure the wheels spin freely. Boost controller?
Old Feb 7, 2007 | 05:28 PM
Default Re: No boost.. (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">wastegate? Make sure the wheels spin freely. Boost controller?</TD></TR></TABLE>
thats what i was thinking. i am his good friend and he just brought it to my house. and there is no boost controller
Old Feb 7, 2007 | 05:29 PM
Topdawgg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Also.. I said its putting out 0 psi. </TD></TR></TABLE>
yes, which is charge piping SOMEWHERE
check it over again
Old Feb 7, 2007 | 05:30 PM
its a turbonetics wastegate and i have heard some pretty bad things about them.
Old Feb 7, 2007 | 05:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 Em1 &raquo;</TD></TR><TR><TD CLASS="quote">its a turbonetics wastegate and i have heard some pretty bad things about them.</TD></TR></TABLE>
Anyone have any info on the delta gate?
Modified by Boostedb20EH2 at 9:54 PM 2/7/2007
Old Feb 7, 2007 | 05:53 PM
Old Feb 7, 2007 | 05:56 PM
This sucks
Im guessing my deltagate went out.
Tial next ftw
Old Feb 7, 2007 | 05:58 PM
AWDstylez's Avatar
Even a stuck open wastegate will at least creep to 1-2psi by redline, unless you're running like a 44mm on a 1.5L and a huge turbo.
So what's the verdict on the charge pipes? Are the wheels even spinning? Did you hear turbo noise?
Old Feb 7, 2007 | 06:02 PM
Default Re: (AWDstylez)
Visually checked throughly. I will do a full air test this weekend. And yes,i do hear the turbo noise,just no positive output along with it.
Old Feb 7, 2007 | 06:04 PM
AWDstylez's Avatar
My BOV once got frozen open on a sub 0* day and caused a no boost condition. But it also noticably changed the turbo sound, made it very muffled as if it was blowing through a thick foam pad. Mine is recirculated though, an open air one might not make much of a sound.
Old Feb 7, 2007 | 06:14 PM
it has been like -8 the past couple nights maybe even colder but im not sure but i think his car sits in a heated garage
Old Feb 7, 2007 | 06:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWDstylez &raquo;</TD></TR><TR><TD CLASS="quote">My BOV once got frozen open on a sub 0* day and caused a no boost condition. But it also noticably changed the turbo sound, made it very muffled as if it was blowing through a thick foam pad. Mine is recirculated though, an open air one might not make much of a sound.</TD></TR></TABLE>
Yeah,but the car had been running for awhile,and this was after a fairly high boost. (redlined 2nd gear). Then after that no boost.
Old Feb 7, 2007 | 06:48 PM
SlowPokeEg's Avatar
Mike Jones
Default Re: (Boostedb20EH2)
Git R Done
External Wastegate FTL! jk
Old Feb 7, 2007 | 06:58 PM
pheurton-skeurto's Avatar
yeah, to hell with this recent ohio weather. i just want to wash my car at some point.
as for your boost problem, its obviously a large boost leak. i would triple check all charge piping before i even considered buying new parts. check couplers for wear/holes/cracks/etc. it really sounds like a charge piping leak.
Old Feb 7, 2007 | 07:05 PM
Default Re: (pheurton-skeurto)
[QUOTE=pheurton-skeurto]yeah, to hell with this recent ohio weather. i just want to wash my car at some point.
for ohio weather right now.
Old Feb 7, 2007 | 07:13 PM
1158's Avatar
Inspect your couplers...make sure they ain't fuct
Old Feb 8, 2007 | 10:56 AM
Default Re: (1158)
thanks guys
