Silicone Intercooler Pipe???
Old Feb 7, 2007 | 06:05 PM
integrainside's Avatar
Default Silicone Intercooler Pipe???
Was just reading about this silicone intake system. Wondering if anyone knows anything about it or even had experience with it. Any and all comments, advice, and oppinions welcome! Thanks!
Old Feb 7, 2007 | 06:16 PM
blackeg's Avatar
Default Re: Silicone Intercooler Pipe??? (integrainside)
i know some vw and audi turbo setups use a lot of silicone for the intake piping, so it can work
Old Feb 7, 2007 | 06:21 PM
vtec.dc2's Avatar
it is as simple as it sounds, if it doesn't leak then it will do the job. concerns would be for it to retain shape and not flex too much as engine moves and probably overall cost. aluminum will work just fine and works well with heat, you can go with better metal but you'll be paying arm/leg and for something that already works for thousands.. why reinvent the wheel
Old Feb 7, 2007 | 06:32 PM
CivicVX94's Avatar
Default Re: Silicone Intercooler Pipe??? (vtec.dc2)
wasn't there a thread around here a while back about making custom silicone intake piping??? if you search around i'm sure you can find it...i'm almost positive it was here
Old Feb 7, 2007 | 06:39 PM
CivicVX94's Avatar
Default Re: Silicone Intercooler Pipe??? (CivicVX94)
ahh....i can't find it.....
i did find this tho...you could prolly come damn near to making all your charge piping with these pieces.
https://honda-tech.com/zerothread?id=1855259
Old Feb 7, 2007 | 06:52 PM
Boilermaker1's Avatar
I had a mostly silicone setup for a while, it worked pretty well and it wont heat up like metal pipes will. Just use the 4 ply silicone, not the cheap stuff.
Definitely useable, but its possibly more expensive than just making them out of metal.
Old Feb 7, 2007 | 11:39 PM
Tony the Tiger's Avatar
It gets expensive real quick... Other than price, there aren't any drawbacks with using silicon tubing for most of the charge connections. Well, it won't look as good as polished SS or aluminum piping either.
Old Feb 9, 2007 | 12:08 AM
Heres the link to the company i was looking at...
http://www.siliconeintakes.com/
PreludeJunkie91
Oct 3, 2018 11:22 PM
fjt
Jun 7, 2004 12:24 PM
civtic
Jan 10, 2004 06:00 PM
turbotypeR@SPEC
Jan 20, 2003 05:05 AM
NeXtLeVeL_TyPe_R
Aug 8, 2002 06:47 PM
