Almost ready for a tune.....
Old Feb 1, 2007 | 09:48 AM
slowhonduh93's Avatar
Default Almost ready for a tune.....
but my car won't idle.... will the tuner be able to fix it or atleast tune it so that I'm not running rich when my car is trying to idle... set up....
stock B16a2
turbonetics 57trim .63 ar t3/t4 turbo
walbro 255
spearco 6" fmic
custom 3" dp
3" turboback Kteller exhaust
deltagate 9psi spring wg
greddy type s bov
chipped ecu... hoping to get a tune with crome
550 rc injectors
msd external coil
cheap ebay manifold(braced)
skunk2 IM
last time I had it tuned... idle was erratic, made 256whp and 178wtq with different manifold, had a 2.25 dp with cat and ws catback... any feedback would be appreciated... and please no flaming about the manifold... i know you get what you pay for... the last setup also had a ebay manifold and never cracked...
Old Feb 1, 2007 | 10:02 AM
adseguy's Avatar
Default Re: Almost ready for a tune..... (slowhonduh93)
Yes the tuner will fix the idle as long as it's a tuning problem and not an ignition problem or anything else not related to the tune itself. GL
Old Feb 1, 2007 | 02:10 PM
thanks for the reply... its been doing it since it was swapped.... I changed the iat sensor and it stopped... put turbo in... started again.... I'm confused...
Old Feb 1, 2007 | 02:12 PM
Synapse Motorsport's Avatar
Default Re: (slowhonduh93)
Does it hunt up and down, could be a vacum leak.
Old Feb 1, 2007 | 02:23 PM
I know for sure its not a vacuum leak... checked that many times over.... Like I said it did it when I was NA, but when I changed the iat sensor it stopped... then I put the turbo and now its back....
hateshino
Jun 1, 2010 10:39 AM
swapped95
Sep 17, 2006 12:34 AM
Snafu-Si
Aug 28, 2006 04:33 PM
Autoworks
Jun 13, 2006 10:49 AM
irocdaparty85
Apr 27, 2006 07:11 AM
