B18c or B20B
Old Feb 6, 2007 | 03:33 PM
lowcrx1's Avatar
Default B18c or B20B
Hi guys ,just wondering would anyone give me advise or what would be the best build,here goes
iv got a 1989 honda crx,with b18c stock internals,b16a,custom intake plenum,runing tdo5 turbo,so and so, im going to forge the motor with cp piston and eagle h beam rods,with a garret gt 35/40 r turbo ,running prob apexi power fc or chrome,but im thinking if i should use a b20b block and forged that or should i stick with my b18c ,i want more power from my motor
cheers any iinfo is much apreciated
Old Feb 6, 2007 | 03:57 PM
doood's Avatar
been there done that
Default Re: B18c or B20B (lowcrx1)
you're going to need to resleeve a b20 to handle a lot of power. or have a very good tune with it. stick with your b18c and resleeve/overbore that if you want extra displacement.
Old Feb 6, 2007 | 07:09 PM
morgan@synapse motorsport's Avatar
how much power do u want to make, unless u sleeve one of those blocks you wont be able to use the 35r to its fullest potential. if u dont want to sleeve it i would suggest going with a 30r to maximize the powerband.
Old Feb 7, 2007 | 03:54 PM
lowcrx1's Avatar
cheers for the info,
i want atleast 300 + Kw at the wheels,would stock sleeves handle that sort of power ,how much does sleeves normally cost
cheers
Old Feb 7, 2007 | 04:15 PM
boosted92's Avatar
Default Re: (lowcrx1)
300 kw is only about 400 horsepower. People have done around 650 whp on stock B18 sleeves, or about 485 kW. A sleeved block from Golden Eagle will run you 950 USD plus shipping, without a core. I'd probably ditch the GT35R and pickup a 30R as well, and put forged pistons/rods into your B18C block. I would not trust stock B20 sleeves at 300kW.
Old Feb 7, 2007 | 05:07 PM
lowcrx1's Avatar
cool thanks for that,
so i should get a gt 30r turbo,im going to use cp piston and eagle rods,getting told to use apexi power fc ,but to much hassel as my ecu is a obd1 first gen crx,was told i need ctr ecu loom and dizzy,which is gonna be difficukt to find,could i use a chrome chip or any other type of ecu thats not to expensive
cheers for the help guys much appreciated
95ITRJDM
Dec 13, 2011 08:12 PM
Piv
Aug 27, 2010 09:42 PM
carcala
12
Sep 18, 2002 07:50 AM
