at what boost levels are you guys modding your stock PCV system?
Old 04-23-2007, 01:37 PM
the.hamburglar's Avatar
Default at what boost levels are you guys modding your stock PCV system?
im booting 7psi at the moment and i was just wondering when some of you are modifying your stock pcv system so you dont have that excess pressure inside your crank case. just curious.
also, would removing that pcv valve affect idle? i mean it would be like a giant vacuum leak wouldnt it?
Old 04-23-2007, 01:54 PM
crxnj's Avatar
Default Re: at what boost levels are you guys modding your stock PCV system? (the.hamburglar)
Alot people tell me to upgrade,but i have the stock pcv system still with just a breather on the valve cover. 25 lbs 530whp and it runs fine
Old 04-23-2007, 02:16 PM
Default Re: at what boost levels are you guys modding your stock PCV system? (crxnj)
do you know if the car would idle alright with the pcv gone?
Old 04-23-2007, 02:52 PM
HiProfile's Avatar
Since the PCV valve is essentially a pressure-dependent check valve, I don't see why it wouldn't idle after removal, assuming you readjust the idle. It would be the same as removing a small vacuum leak on a motor that idled fine with it. You have less blowby at idle than a woman's *** does from farts (so they claim).
Old 04-23-2007, 02:58 PM
vtec.dc2's Avatar
heres my setup
extra vents never hurt and always useful esp. it can reduce pressure if you happen to have smoke out the valve cover. there should never be smoke or very minor with hundreds of hp at peak of that hp..
its somewhat stock, no catch cans.. just more vents and i still utilize stock pcv valve for partial throttle. stock pcv valve is not designed for boost so i use stock brake check valve (2 of them) to prevent damage.
Old 04-23-2007, 03:00 PM
mike1114's Avatar
Default Re: at what boost levels are you guys modding your stock PCV system? (vtec.dc2)
It only took 5 posts for someone to whip out the crayon drawings, new record!!!
Old 04-23-2007, 03:01 PM
vtec.dc2's Avatar
the more blowby you have, the more you need you have for extra vents. my setup would smoke at wot and higher rpm out valve cover when valve cover was the only vent.. there is no more smoke after current setup showed in above picture..
vtec.dc2's Avatar
Default Re: at what boost levels are you guys modding your stock PCV system? (mike1114)
ms paint ftw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">It only took 5 posts for someone to whip out the crayon drawings, new record!!!</TD></TR></TABLE>
Old 04-23-2007, 03:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">heres my setup
looks good, so you just vent the 3/8" lines out to the atmosphere? you should post some pics of your real engine bay
Old 04-23-2007, 04:11 PM
vtec.dc2's Avatar
i don't think i posted the right size of an fittings for these line.. i'm pretty sure its 3/8" its same diameter that goes onto factory valve cover fitting
using a bit larger wouldnt hurt. i went with that size to match match ID of stock fitting
so far over 30k miles and no problems
Old 04-23-2007, 08:00 PM
ok, so where do the blue lines go to then? i imagine they are about a 5/8" diameter as 3/8" seems to be really small. why do you have those 2 inline check valves?
Old 04-23-2007, 08:34 PM
vtec.dc2's Avatar
thats to prevent pressure from going into crankase.. these blue lines vent into atmpsphere
Zaraki
06-22-2013 08:57 PM
turbo_d16
06-18-2011 10:22 AM
k20rex
07-21-2006 02:19 AM
caliquick_teg
01-23-2003 05:34 AM
Quick Reply: at what boost levels are you guys modding your stock PCV system?
