Only boosting like 2 psi
Old Apr 23, 2007 | 03:02 PM
h22a_junkie's Avatar
Default Only boosting like 2 psi
Hey guys, this seems like it should be easy to fix but I can't find it. I am only getting about 2 psi of boost on my new setup. I have a hybrid Garrett T25/ T3 hybrid turbo with an external wastegate. I Have my vacuum on the side port of the wastegate hooked to the outlet brass fittings on the turbo. I don't have anything hooked to the top port of the wastegate. I went on a test run today and when I came back in the driveway The hot side of the intercooler felt hot along with the charge piping, and the cold side felt cold. I checked all of my couplings and they felt secure. How can I tell if the wastegate isn't fully closed? The release port of the wastegate is vented to the atmosphere and I don't feel or see any gases coming out. 2 psi sucks *****!
Old Apr 23, 2007 | 03:55 PM
95dc2teg's Avatar
Default Re: Only boosting like 2 psi (h22a_junkie)
try hooking up the wastegate to a different vacuum source, like the brake booster.
Old Apr 23, 2007 | 04:02 PM
shortyz21's Avatar
Default Re: Only boosting like 2 psi (95dc2teg)
if no exhaust is coming outta the wastegate, then it aint open..
u either got a leak or a fucked up turbo..
p.s. check your bov to make sure its sealing.
Old Apr 23, 2007 | 04:40 PM
I have tried just leaving the wastegate unhooked completely and it didn't work. I just went and bought a new boost gauge because my old autometer was horribly inaccurate. I am actually boosting at 1psi, barely enough to make the check engine light come on. I have tightened down the adjustment srew on the blow off valve. How could I tell if the turbo has had it? I don't have any oil coming from it.
Old Apr 23, 2007 | 04:43 PM
95dc2teg's Avatar
Default Re: (h22a_junkie)
is it spinning when the car is on?
Old Apr 23, 2007 | 05:04 PM
no, not at idle. you have to throttle up the engine before it starts to spin
Old Apr 23, 2007 | 05:10 PM
vtec.dc2's Avatar
check all charge piping connections.. make sure there aren't any leaks.. or make your own pressure testing kit to find the source for the leak
Old Apr 23, 2007 | 06:16 PM
2redstars's Avatar
did you put that ring on the bottom of the wastegate on? i think its called the fire ring or something like that.
Old Apr 24, 2007 | 06:28 AM
shortyz21's Avatar
Default Re: (2redstars)
i think the fire ring is to seal the flange to the manifold...
Old Apr 24, 2007 | 06:41 AM
Running925's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22a_junkie &raquo;</TD></TR><TR><TD CLASS="quote">no, not at idle. you have to throttle up the engine before it starts to spin</TD></TR></TABLE>
looks to me like your answering your own question here
Old Apr 24, 2007 | 06:47 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22a_junkie &raquo;</TD></TR><TR><TD CLASS="quote">I have tried just leaving the wastegate unhooked completely and it didn't work</TD></TR></TABLE>
you should get TONS of boost that way. sounds like maybe you have a big boost leak?
Old Apr 24, 2007 | 10:01 AM
I can't see where it would leak before the turbo. Unhooking the wastegate makes NO difference. Under acceleration, you can hear the turbo spool up and it sounds awesome but the gauge never reads above 1.5 psi and it feels that way as well!
Old Apr 24, 2007 | 10:16 AM
under_boost's Avatar
pressure check your charge pipes man. same as your last thread. if pressure doesn't hold, spray some soapy water around the connections until you see bubbles. if no bubbles exist, your turbo is done.
Old Apr 24, 2007 | 11:09 AM
2redstars's Avatar
Default Re: (under_boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">i think the fire ring is to seal the flange to the manifold...
but if its not in wont it let air past the valve?
dude, just check it, youve checked everything else.
take the wastegate off and look at the side that connects to the manifold. is it sealed, or is there a gap that you can see past
Old Apr 24, 2007 | 11:40 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22a_junkie &raquo;</TD></TR><TR><TD CLASS="quote">I can't see where it would leak before the turbo. </TD></TR></TABLE>
I said boost leak, meaning your charge pipes, not the hot side.
Old Apr 24, 2007 | 05:08 PM
alright, just took the wastegate off and yes, the fire ring is there. it also takes a great deak of force to get the valve to open so I don't think my issue is coming from the wastegate. I am trying to figure out the best way to pressure test the charge piping. I though about buying some kind of flexible hosing that I can run from the turbo directly to the throttle body, ghetto but it should also tell me if its the turbo or charge piping.
gsr x civic
Apr 7, 2007 09:57 AM
aracer69
Jul 7, 2003 07:47 PM
yorktonite
Aug 20, 2002 04:37 AM
