91oct + E85??????
Old Apr 22, 2007 | 09:41 AM
Flipnotize21's Avatar
Default 91oct + E85??????
would it be a probb if you mixed 50/50 of 91oct & E85? what rating would that land on, i dont know what oct the E85 is.. because here 100oct is 6.30per gal.. and they sell 108oct for around $7per gal....... i was thinkiing if i can mix E85 with 91..
Old Apr 22, 2007 | 10:07 AM
bigbadboy's Avatar
why not just run full E85?? its 105 oct.
Old Apr 22, 2007 | 10:15 AM
tony413's Avatar
Default Re: 91oct + E85?????? (Flipnotize21)
E85 is usually 105 octane also i dont know about mixing it 50/50 i usually see it mixed with 70% or more gas to 30% or less alcohal
bigbadboy running 100% alcohal requires a better supporting fuel system an that can be costly. also mixing the fuels is to check detenation in check and since alcohal burns cooler it carries the torque line higher into the rpms
Old Apr 22, 2007 | 11:15 AM
SOHCEK-Turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flipnotize21 &raquo;</TD></TR><TR><TD CLASS="quote">would it be a probb if you mixed 50/50 of 91oct & E85? what rating would that land on, i dont know what oct the E85 is.. because here 100oct is 6.30per gal.. and they sell 108oct for around $7per gal....... i was thinkiing if i can mix E85 with 91..</TD></TR></TABLE>
Were are you getting the E85 from?? I see you live in the 818. LMK
Old Apr 22, 2007 | 09:13 PM
bigbadboy's Avatar
i never said run alcohol. i just told him instead of mixing E85 and 91. just run E85. its already mixed for you. plus when you mix it yourself your never going to get a consistant mix
Old Apr 22, 2007 | 09:22 PM
tony413's Avatar
measure out how much you mix together
Old Apr 22, 2007 | 09:51 PM
CivicVX94's Avatar
E85 is 85% ethanol and 15%petroleum and is equivilant to ~105-106 octane.
It has a much lower air/fuel ratio to be in stoich conditions (i think 9:1), so it will require larger injectors inorder to supply to additional fuel. I think it ends up coming down to requiring 30%more fuel for E85 than normal gasoline, so basically, you'll need to be able to flow 30% more fuel-whether that means larger injectors, larger fuel line..etc...
Mixxing the two is a not a good idea. THe fact that E85 is already a mixed solution can throw things off to begin with...then mixing it with gas couldn't help things.
I have no idea how to figure out what the octane rating would be,nor do i have any idea how you could figure it out.fyi.. It's not the same as mixing 91 octane and 87 octane gas...
My advice, if you're wanting to push more power on the street than 91octane can take, get alocohol injection. Set it up so that it only sprays at WOT and you'll be good to go
Old Apr 25, 2007 | 04:42 AM
Thanks for all the 411 good looking out...
Old Apr 25, 2007 | 06:23 AM
CivicVX94's Avatar
Default Re: 91oct + E85 (Flipnotize21)
Glad i could help
creechrr
May 14, 2007 04:11 PM
.water
Oct 15, 2005 11:05 AM
