Wanted to share some pics of XS Power Top Mount Turbo Kit
We're putting this kit on a customers freshly rebuilt B18C1 in an EG chassis. Thought we'd share some pics. As a baseline, the car dyno'd at 153whp on our DynoJet. We'll keep you guys posted to the progress. Enjoy the pics!
Below are pics of the XS Power top mount manifold and his turbo. Not sure on the turbo specs, I'll report back on those later.
Modified by prostreetonline at 7:12 PM 4/26/2007
Re: Wanted to share some pics of XS Engineerings Top Mount Turbo Kit (prostreetonline)
Umm, XS Engineering is a very reputable company out of Cali, please don't mix them up with XS Power garbage....
Re: Wanted to share some pics of XS Engineerings Top Mount Turbo Kit (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Umm, XS Engineering is a very reputable company out of Cali, please don't mix them up with XS Power garbage....</TD></TR></TABLE>
Thanks for that... changed the info. It won't let me change the title
Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">sucks that turbo isn't twin scroll..</TD></TR></TABLE>
At least it looks like they paired the right runners.
The whole WG placement blows my mind though.
Re: (EJ1 wilcox)
the title is going to confuse alot of people.
should have it locked, and restart it, with the correct company name.
easy mistake though, Prostreet
xs power
xs power
Re: (EX-T)
this is great i got the same turbo and manifold i just been waiting for money for a tune. cant wait to see what it spools at. the turbo is xs power t70
64.5 shaft and wheel trim
60.5 mm compressor wheel
a/r .84 turbine housing
a/r .70 compressor housing
p.s. nothing fits together smoothy is modify all the way .
Re: (wade)
x2
x2
Re: (PhantomX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantomX »</TD></TR><TR><TD CLASS="quote">whats the manifold Called??</TD></TR></TABLE>
i believe they try to call it the full race T4 top mount.
I have one for hella cheap if any one wants to buy it.
Re: (Turbo O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo O »</TD></TR><TR><TD CLASS="quote">i believe they try to call it the full race T4 top mount.
I have one for hella cheap if any one wants to buy it.</TD></TR></TABLE>
define hella cheap
define hella cheap
NooB
exactly what i was gonna post..
Re: Wanted to share some pics of XS Engineerings Top Mount Turbo Kit (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 »</TD></TR><TR><TD CLASS="quote">It used to be if you had a turbo honda you knew what you were doing, now we all look like masters of the rice </TD></TR></TABLE>
Re: Wanted to share some pics of XS Engineerings Top Mount Turbo Kit (Flashmn)
Junk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn »</TD></TR><TR><TD CLASS="quote">Whats wrong with the compressor wheel, looks like its chipped?</TD></TR></TABLE>
See above.
Junk.
See above.
Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">Let us know how it all turns out! </TD></TR></TABLE>
The manifold does not fit well. The block has to be shaved, and the location of the wastegate and the downpipe makes this "A/C Compatiable" kit non A/C compatiable.
Only a stock single core radiator will work, and the radiator fan has to be a pusher rather than a puller. With the size of the FMIC, and the radiator fan being a puller, we warned the customer of possible overheating issues.
The radiator hoses also will not work as the turbo sits right in front of the radiator inlet.
The oil return line does not make me feel comfortable either. It will have to be flat for a good portion of it's length, and we do not recommend this.
The wastegate flange does not match with the flange from the manifold.
We have advised the customer to get a different manifold. If he decides to keep this one, we will have to do a lot of custom fabrication to get everything to work for his street car. If it was a race car it would be a different story.
We do not recommend this kit.
Re: (prostreetonline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prostreetonline »</TD></TR><TR><TD CLASS="quote">
We do not recommend this kit.</TD></TR></TABLE>
No doubt, sounds like the customer is going to spend a lot of money to have you guys do the fab work to get this manifold to work properly. It would probably be cheaper for him to start out with a little more expensive manifold that wouldn't require so much modification.
Re: (EJ1 wilcox)
We've advised him to get a different manifold... but the customer likes the "bling" factor, so it's up to him. He does seem to be leaning toward getting a different manifold, and selling this one, so we'll keep you guys posted on his car's progress.
