Cast Iron.
Old Apr 25, 2007 | 11:03 AM
envee's Avatar
Default Cast Iron.
As we all know, cast iron does rust. My question is, since my manifold that is stilling in my garage will undoubtly rust before it is install, what is the best way to get the rust out from inside the manifold? i don't want rust to be blown into my turbo when it is first started up. Thanks.
Old Apr 25, 2007 | 12:31 PM
inspyral's Avatar
You could coat it with some WD-40.
Old Apr 25, 2007 | 03:39 PM
Patman's Avatar
oil and bag it
Old Apr 25, 2007 | 08:02 PM
envee's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">You could coat it with some WD-40.</TD></TR></TABLE>
i was thinking that, but that **** smells when it heats up and it doesn't seem that it would be good for the turbo. even tho it probably burns off very quickly.
Old Apr 25, 2007 | 08:03 PM
envee's Avatar
Default Re: (Patman)
same deal. will smell like hell on start up, although oil would probably be better than wd40. thanks.
Old Apr 25, 2007 | 08:10 PM
Boilermaker1's Avatar
if you oil it, then shoot it with degreaser or brake cleaner before you install it, then both problems are solved.
integra3586
May 14, 2007 02:25 PM
DelSolMike
Apr 15, 2006 06:43 AM
HondaH22A
Oct 3, 2005 06:47 PM
95hatchfire
Aug 19, 2004 10:52 AM
Damon B.
Dec 14, 2002 10:27 AM
