ARP Headstud washers...
I lost one of these damn things. Can i just go to my local home depot and find a washer thats close/same to the others and it should be ok??
Any one else done this, what did you do
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyimport »</TD></TR><TR><TD CLASS="quote">I lost one of these damn things. Can i just go to my local home depot and find a washer thats close/same to the others and it should be ok??
Thanks</TD></TR></TABLE>
No - you cant do that. Washers at home depot will crush differently then the other washers in the motor and could cause a head bolt getting loose.
Call ARP at 800.826.3045 or visit http://www.arp-bolts.com/
You can buy the washer by itself, will only cost you a few bucks.
liam
liam
I'd actually call up Lightning Motorsports, they hooked me up twice with individual ARP parts I needed. They are well-priced and ship fast. Otherwise get it from the horse's mouth.
I had the same problem on a built motor. Replaced it with a stainless washer that i had laying around and it's been fine for well over a year.
take that for what it's worth, i'm not recommendng it but it's worked for me.
ARP washers for headstuds are ground flat as ***** so the load of the nut is directed perpendicular to the bolted surface. the washers from home depot are ground using gay methods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 »</TD></TR><TR><TD CLASS="quote">ARP washers for headstuds are ground flat as ***** so the load of the nut is directed perpendicular to the bolted surface. the washers from home depot are ground using gay methods.</TD></TR></TABLE>
Just out of curiosity - why did my friend's set of ARP studs come with spherical washers? We got new ones cause he ended up losing one fo the washers, but I was always curious why the washers were spherical when the nut's flange was flat?
rice a roni
21
Apr 17, 2007 09:23 AM
eg6cusco10pt
10
Sep 23, 2004 05:39 AM
