FMU
Old Apr 20, 2007 | 08:36 PM
ericstambaugh07's Avatar
Default FMU
so i have stock injectors in my prelude..and if i understand right..a can get a fmu and it will be good enough up to 10lbs of boost? this will be dyno tuned with emanage
Old Apr 20, 2007 | 08:38 PM
95dc2teg's Avatar
Default Re: FMU (ericstambaugh07)
no, just get proper engine managment, there is alot of freeware out there such as crome, uberdata, etc. Engine managment is much cheaper now than it used to be.
Old Apr 21, 2007 | 07:12 AM
Default Re: FMU (95dc2teg)
i do have engine management..i have the greddy emanage..so the fmu is to just replace an ems?
Old Apr 21, 2007 | 07:32 AM
Rob97'SH's Avatar
FMU adds fuel by increasing the fuel pressure on a boosted motor. Its not an ideal way of adding fuel but I guess its okay for a short time. I could be wrong but I think it makes an engine run very rich but its better then too lean.
Old Apr 21, 2007 | 08:32 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericstambaugh07 &raquo;</TD></TR><TR><TD CLASS="quote">so i have stock injectors in my prelude..and if i understand right..a can get a fmu and it will be good enough up to 10lbs of boost? this will be dyno tuned with emanage</TD></TR></TABLE>
No.
I am not a fan of the emanage units. If you do want to use this system, make sure you have the ignition add-on. Simply adding fuel without retarding your timing is asking for a blown motor... especially since this is what loves to kill the ringlands on the H series pistons.
Old Apr 21, 2007 | 07:02 PM
Default Re: FMU (PrecisionH23a)
well i do have both wiring harnesses..the ignition and injector wiring..and i also have a msd sport compact box with a msd coil so i am planning on upgradding the ignition
Old Apr 21, 2007 | 08:57 PM
93CX's Avatar
this thread sucks.
Old Apr 21, 2007 | 09:12 PM
mtber's Avatar
I answer questions like this 10x a day :-P
My simple answer, read http://phearable.net/tech/efibeginnerguide.html
Old Apr 21, 2007 | 09:16 PM
DfwBB6's Avatar
Default Re: FMU (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">I answer questions like this 10x a day :-P
very well said.
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">No.
I am not a fan of the emanage units. If you do want to use this system, make sure you have the ignition add-on. Simply adding fuel without retarding your timing is asking for a blown motor... especially since this is what loves to kill the ringlands on the H series pistons.</TD></TR></TABLE>
I HATE emanage. I tuned it on a honda before and it wasn't too bad of an experience, but when i've tuned it on other car makes the stock ecu would fight the emanage terribly at partial throttle making it very hard to tune.
joshfish79
Mar 6, 2007 09:59 PM
turbogsr18
Jul 23, 2006 06:27 PM
kovert
Aug 17, 2004 09:58 AM
stinker504
Sep 15, 2003 05:38 AM
94dxt
Apr 24, 2003 12:07 PM
