Cleaning Write up DIY 56K beware
Old Apr 20, 2007 | 10:26 PM
tony413's Avatar
Default Cleaning Write up DIY 56K beware
well i brought a motor for the local junk yard for $300 and thought it would be great for a 500-700hp DD, circuit track, and occasional strip car so stay tuned for that thread. Now this is a write up of how to clean parts.
first a little before an after shots
before
after
rocker arms
intake ports after cleaning
the head itself which will be cleaned in my little bath
the supplies
1. get a 18 gallon or more container
2. fill the container with a 3 parts cleaner to 2 parts DISTILLED water solution. ( in the pic above i only used 3 gallon of cleaner and 2 gallons of water haha )
3. allow parts to sit in solution for NO longer than 45min. i produced the results above with only 15-30min. of soaking time
4. while parts are in solution scrub thoroughly
5. after parts are to your liking dry as best you can
6. give most parts a LIGHT coat of WD-40 to prevent rust ( i didnt do this on the pics above but it works better when you do )
now you may be wondering what is the gunk motor flush for ? well its to pre soak really hard to clean parts that have oil burned on or other containminants. after you do that then complete steps 1-6 hope you guys enjoyed the write up and pics OH BTW i will be doing the WHOLE cylinder head once i get the sensors off so keep checking for updates
Old Apr 21, 2007 | 07:04 AM
methos713's Avatar
Default Re: Cleaning Write up DIY 56K beware (tony413)
nice
Old Apr 21, 2007 | 08:17 AM
CivicVX94's Avatar
Default Re: Cleaning Write up DIY 56K beware (methos713)
hell ya man
I have quite a few parts that could use this lol
Old Apr 21, 2007 | 08:20 AM
spoolingb20's Avatar
Parts washer (hot tank) will work just as well and alot less scrubbing....
Old Apr 21, 2007 | 09:56 AM
90dxhmt's Avatar
Default Re: Cleaning Write up DIY 56K beware (spoolingb20)
Home made parts cleaner tank
Old Apr 21, 2007 | 10:19 AM
jdizzle!
Guest
Posts: n/a
Default Re: Cleaning Write up DIY 56K beware (90dxhmt)
cool
Old Apr 21, 2007 | 11:28 AM
simply's Avatar
quick question, the stuff like the rocker arms can they be used in the head in any place, like if they get mixed up. Or should they be placed in the same spot you removed them from?
Old Apr 21, 2007 | 11:45 AM
tony413's Avatar
Default Re: (Cindy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cindy &raquo;</TD></TR><TR><TD CLASS="quote">quick question, the stuff like the rocker arms can they be used in the head in any place, like if they get mixed up. Or should they be placed in the same spot you removed them from?</TD></TR></TABLE>
nope the rocker arms can work in any place of either they wont get mixed up but if you want added security do each part in groups like all the intake things together and then all the exhaust things together
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolingb20 &raquo;</TD></TR><TR><TD CLASS="quote">Parts washer (hot tank) will work just as well and alot less scrubbing....</TD></TR></TABLE>
do you own a $800 hot aqueous solution tank ? im just offering a cheaper $25 alternative that people can do home also if you let these parts sit for about an hour or more you will not need to scrub a thing depending on how strong you make the solution.
Old Apr 21, 2007 | 03:30 PM
Jared's Avatar
damn, someone should have changed their oil more often.
Old Apr 21, 2007 | 09:07 PM
hector3300's Avatar
Default Re: (Jared)
this sounds like a cheap solution to cleaning grimming parts. if you dont mind me asking whats the total costs in supplies for cleaning your entire enigine? looks really nice and has promising results without the down time of taking it to a shop. nice job.
Old Apr 21, 2007 | 09:14 PM
DfwBB6's Avatar
Default Re: (hector3300)
nice write-up
Old Apr 21, 2007 | 09:34 PM
tony413's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">damn, someone should have changed their oil more often.</TD></TR></TABLE>
haha it wasnt from not changing the oil but running the car a little too hot i brought it that way because it was still in good condition and i knew i could fix it
also the total cost of supplies was cheap heres a break down
3 gallons of purple power-- $12.36
2 gallons of distilled water-- $ 1.28
one 18 gallon container-- $ 5
scrubing brush-- $1
tire brush--- $1 ( this is the long conical brush, i used it to clean the ports
total cost $ $20.64 while the average hot tank price that i've been seeing is $50-$80
Old Apr 21, 2007 | 11:08 PM
whatugot's Avatar
right on...
Old Apr 22, 2007 | 04:17 PM
khaosman's Avatar
Cool! I have parts that could use a bath. Thanks
Old Apr 22, 2007 | 05:02 PM
mtny's Avatar
Default Re: (khaosman)
Interesting write-up can't wait to see some more progress.
Old Apr 22, 2007 | 10:40 PM
tony413's Avatar
Default Re: (mtny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtny &raquo;</TD></TR><TR><TD CLASS="quote">Interesting write-up can't wait to see some more progress. </TD></TR></TABLE>
thanks alot i just cant wait to hear the car start and make my first 11 pass in it
Old Apr 22, 2007 | 10:58 PM
miyagi's Avatar
looks good man... nice write up and good luck with the setup
I spray my bay with parts cleaner and a blast of air from a compressor on occasion to keep things looking crisp
RICKYritethere
Feb 10, 2009 06:05 PM
tony413
Jun 16, 2007 07:04 AM
.1type.
Dec 1, 2005 09:08 AM
sweetcarz02
May 14, 2005 07:26 PM
S@nt0s
May 17, 2004 01:43 PM
