can someone give me some realistic dyno numbers on a b20b/vtec turbo swap
hey guys...i had a stock gsr boosted swap in my 99 si at about 6lbs before...and now due to some comeups im now building a b20/vtec for my car...
i keep hearing mixed things can someone please give me some realistic dyno numbers i should be looking for i have these things for the build:
b20b block
stock bottom end
arps
thicker (.054) cometic head gasket
gsr head
aftermarket valvetrain
flat faced omni valves
drag gen 3 turbo kit
2.5 inch dp all the way to the greddy exhaust
t3/t4 .50/.63 ar housing
gsr lsd tranny
lighter flywheel and exedy clutch
550cc injectors
hondata s300
thanks guys for all your help
b20b block
stock bottom end
arps
gsr head
gsr lsd tranny
550cc injectors
hondata s300
Re: can someone give me some realistic dyno numbers on a b20b/vtec turbo swap (hbboostman)
wow those are the numbers i was thinking...how many lbs of boost did you run?
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbboostman »</TD></TR><TR><TD CLASS="quote">hey guys...i had a stock gsr boosted swap in my 99 si at about 6lbs before...and now due to some comeups im now building a b20/vtec for my car...
b20b block
stock bottom end
arps
gsr head
gsr lsd tranny
550cc injectors
hondata s300
Why not sleeve the block to 84mm and throw in an LS/B20 Crank? This has been done with some good results. Last one we did made 332whp@249 ft/lbs at only 12psi. IS it more of a cost concern?
b20b block
stock bottom end
arps
gsr head
gsr lsd tranny
550cc injectors
hondata s300
its more about the cost than anything else...i got the whole longblock for 450$ and ive built a hybrid before so i have the knowledge and know how..so i said why not...i just dont have the money to the sleeves,pistons, and rods..and im really not looking to own the streets...its mainly for personal use and some weekend track fun....
jonyb
12-28-2002 10:24 AM
