dyno prof changes
Old Apr 21, 2007 | 01:37 PM
anton_'s Avatar
Default dyno prof changes
how many of you have change something on your motor and made a dyno to se how moch it made.
for a example, change cams, air filter, intake manifold
post your results here
Modified by anton_ at 3:01 PM 4/21/2007
Old Apr 21, 2007 | 01:59 PM
NJIN BUILDR's Avatar
Default Re: dyno prof changes (anton_)
That's pretty much the reason for a dyno.
Old Apr 21, 2007 | 02:03 PM
anton_'s Avatar
Default Re: dyno prof changes (NJIN BUILDR)
i know that but i ment that all should post the results here
Old Apr 21, 2007 | 02:24 PM
vtec.dc2's Avatar
when i make changes.. i don't simply go to a dyno and wot.. i get it retuned and of course you get differnt results.. its as simple as you put it.. increase piping diameter will yeld more hp per psi, larger air filter isn't going to do anything unless your current doesn't flow enough cfm, most people with mild setups don't bother with cams and stick with what they got. when you make tons of hp, any minor change makes a difference.
when spend money for dyno, its not to find out a cat in the box, but to get the results i want. so i research and build whats needed to acomplish that goal. i do'nt just throw anything on to the car and run to a dyno.
Old Apr 21, 2007 | 03:07 PM
Top Ramen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anton_ &raquo;</TD></TR><TR><TD CLASS="quote">how many of you have change something on your motor and made a dyno to se how moch it made.
The forum is full of threads like that (people who have made mods and show before & after dynos). I have seen them for turbos, cams, intake manis, air filters and damn near every other mod you can think of. What is the point of your thread? Do you just want people to re-post everything so you don't have to search?
00Red_SiR
204
Jun 12, 2011 11:49 AM
w4kj4k
Jan 12, 2010 01:09 PM
turboHX
Aug 23, 2004 06:02 AM
