dangerous temps?
Old Apr 24, 2007 | 10:31 PM
I Love my BOOST!'s Avatar
Default dangerous temps?
What are considered dangerous oil temps for oil? Im using 20w-50 Valvoline VR1.
Old Apr 24, 2007 | 10:51 PM
tony413's Avatar
Default Re: dangerous temps? (I Love my BOOST!)
your using 20w-50 on a turbo engine? why ?
Old Apr 25, 2007 | 03:57 AM
NJIN BUILDR's Avatar
If your using oem clearances than 20w-50 is to heavy.Continuous oil temps over over 270* will break down the oil pretty fast.Over 300* and the oil will fail.A rule of thumb is 30* over water temp.that usually puts it at about 210*.
Old Apr 25, 2007 | 07:37 AM
HiProfile's Avatar
Default Re: dangerous temps? (NJIN BUILDR)
Many road racers say their oil hits 240-250 at the most w/o any coolers, and don't have issues. Coolant over 220F is usually a bad idea, so the 30F rule seems to hold true.
Old Apr 26, 2007 | 11:07 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">If your using oem clearances than 20w-50 is to heavy.Continuous oil temps over over 270* will break down the oil pretty fast.Over 300* and the oil will fail.A rule of thumb is 30* over water temp.that usually puts it at about 210*.</TD></TR></TABLE>
Motor is stock.. So 20-50 is too heavy?
Old Apr 26, 2007 | 02:17 PM
rocket256's Avatar
Not to tread jack. Now that its gettin hot out. Do you run heavier oil........10w40
Old Apr 26, 2007 | 03:28 PM
Default Re: dangerous temps? (rocket256)
Thats what I thought, 20-50 I heard was actually good for Hot summer days
Old Apr 26, 2007 | 03:44 PM
shortyz21's Avatar
can anyone chime in on how much diff oil temps are during winter, then summer...
i dont think its much, if any... but i have no idea
Old Apr 26, 2007 | 05:06 PM
tony413's Avatar
here straight from AMSOIL http://www.amsoil.com/frequent.aspx
Old Apr 26, 2007 | 06:07 PM
blackeg's Avatar
Default Re: (tony413)
i always run 10w-40 in my boosted cars, and depending on if its a crap motor ill run lucas as well in there.
i would get concerned if my oil was constantly running over 250ish
Old Apr 27, 2007 | 12:30 AM
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">i always run 10w-40 in my boosted cars, and depending on if its a crap motor ill run lucas as well in there.
i would get concerned if my oil was constantly running over 250ish</TD></TR></TABLE>
So I shouldnt be worried if mine are @ 230ish. When I start to do pulls on the freeway then it shoots up. Maybe Ill invest in an oil cooler...
R-Toyz.com
Apr 4, 2007 05:34 PM
Bense
19
May 19, 2006 05:44 PM
_gurusan_
Jun 4, 2005 09:54 PM
Dan GSR
15
Feb 4, 2004 02:11 PM
SoulSurfer
Nov 8, 2002 06:22 AM
