Valve lash (consequences)
Old Jun 18, 2007 | 01:17 PM
civicsaremean's Avatar
Default Valve lash (consequences)
i recently began to get valve lash on my 97 ls motor, 1 month after going turbo. the noise was minor for a while, but it soon got louder. what will happen eventually? is my engine worn out?
Old Jun 18, 2007 | 01:46 PM
DrivinVtec's Avatar
did you do it right? was cold before doing it? did recheck everything? have you over revved at all?
Old Jun 18, 2007 | 01:53 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Valve lash (civicsaremean)
eventually it will wear out the valve stem tips, and the rockers.
Old Jun 18, 2007 | 04:16 PM
HamiltonRex's Avatar
Default Re: Valve lash (boostedcivicsir)
what if valve lash is set too tight?
Old Jun 18, 2007 | 04:29 PM
Mr. Badwrench
Default Re: Valve lash (HamiltonRex)
if it is a little tight, it will probably burn valves, and if it is really tight, it may coil bind. or float bad and bend.
Old Jun 18, 2007 | 04:56 PM
agrn93ls's Avatar
"VALVE LASH" is the measurement of clearence not what you get when the clearance is too great
not bein an *** just explaining
no the engine isnt worn out. if too much 'lash' it will tap if too little the valve will hang open a bit and you will loose power by loosing compression since the cylinder isnt sealed
set the valve lash under 100*F and the measurements are on the hood. get a good feeler gauge and the feelers should have slight drag too them when you slide them between the camshaft and rocker arm. make sure the valve your setting that the lift on the lobe is facing up and you will be fine.
make sure and rotate engine COUNTER CLOCKWISE when turning it roundy round to move the cams
Old Jun 18, 2007 | 05:45 PM
Mr. Badwrench
Default Re: Valve lash (agrn93ls)
not being an ***, just explaining, but if it is too tight for too long and the valve is held open, you will yes loose compression, but the valve wont transfer heat to the head as well and burn. and if it is too loose it has been known to and will beat the **** out of the valve stem tips and and rocker tips.
so he left out the word excessive, or more than normal causing an audible sound. 2 other people knew what he meant.
Old Jun 18, 2007 | 07:31 PM
agrn93ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">not being an ***, just explaining, but if it is too tight for too long and the valve is held open, you will yes loose compression, but the valve wont transfer heat to the head as well and burn. and if it is too loose it has been known to and will beat the **** out of the valve stem tips and and rocker tips.
so he left out the word excessive, or more than normal causing an audible sound. 2 other people knew what he meant.</TD></TR></TABLE>
word...
didn't say you were wrong just adding more info
Old Jun 18, 2007 | 07:32 PM
Mr. Badwrench
all good.
have a good one.
numotive
Oct 6, 2016 06:57 PM
Robotoyaki
Jan 1, 2010 02:10 PM
kornerk12
Dec 18, 2005 03:27 PM
redpeppers
Jul 26, 2005 02:33 PM
JFG Kevin
Mar 21, 2005 06:39 PM
