What wrong with my turbo?... =(
I just recently took off my turbo kit and running all motor now, here's the problem.
While driving without boosting everything seems fine, then when I'm boost a **** load of smoke will shoot out my exhaust like some smoke screen or something lol then just recently its started making some winding sound when boosting... Somebody help? Is it time for me to get a new turbo? The problem was a kink in the return i believe or it was forcing the oil to travel uphill for the oil return. Fixed all that and still had that smoking and winding problem. Turbo is internally wastegated if that had anything to do with it. Checked my charge piping and there was oil in it..what now?...I'm in like stuck mode. Don't really know what to do.?
Re: What wrong with my turbo?... =( (ProjectEG8)
Not sure what kind of turbo it is, All I know is it's a T3. and a garrett or at least thats what it says. not sure what trim either...
the seals in your turbo may be shot
When oil is forced to travel backwards it can mess some stuff up.
Take it apart and try to get everything cleaned.. Try to get all of the oil out of the charge pipign and as much as you can out of the turbo.
Depending on the oil and howlong it was there will determine if the turbo seals are shot.
Re: (numbnuts22715)
Ok did that cleaned out the charged piping and tried to take apart turbo but for some reason it seems to be stuck...time for new turbo i guess, would it be worth rebuilding, the guy i picked it up from told me it was off a SR20 or something..not sure...
Re: (ProjectEG8)
Rebuild is around 130+ unless your wheels are f'd up which would be more to replace the comp/turbine wheels. Send it in for a quote.
http://www.blaastperformance.c...vices
Re: (ekhatchling)
I'd guess you don't have a restrictor on the oil inlet? 3 main things that can blow seals on the turbo are: 1) excessive pressure from excessive blow-by and/or a crappy pcv/catchcan setup, 2) terrible oil return backing oil into the turbo, 3) high oil pressure on the inlet side (>35psi) due to very little or no restriction on the inlet.
If you are going over ~2500 rpm, you're producing >35psi of oil pressure. Over that you're sending more to the turbo, and upon decel (atmospheric pressure on outside of seals) you have that 35-70psi worth of oil pushing past the seals.
Re: (boostdEM1)
Okay took off the whole turbo kit and now running all stock motor, still debating on what to do. whole new setup or rebuild that one.
to take apart the turbo, you have to turn the comp nut clockwise. righty tighty, left loosey doesn't apply. a used t2 from a sr would cost you about the same as a mild rebuild. or you could get a rebuild kit for about $50 and try urself.
Re: (ProjectEG8)
compressor is the cold side...
definitely sounds like your turbo seals are just shot, i'd replace just the turbo with something bigger if all your other components will support it(injectors, fuel managment,etc)
Good luck.
Good luck.
Re: (Brain3208)
thanks for all the help, I decided I'll just probably sell the kit and save up and pick up a different one or maybe just pick up a new turbo itself.
jrturbokrazy
07-21-2007 07:14 AM
