LS Breather/Catch Can Question
Old Jun 16, 2007 | 07:46 PM
slambedcivic's Avatar
Default LS Breather/Catch Can Question
Alright so this is an old OBD1 block.
Im going to be running a catch can. Ive taken all of my breather stuff out and if im correct I am supposed to convert #1 to a nipple to run to my catch can. #2 gets plugges with a threaded plug, and #3 gets a freeze plug pressed into it. Right?
And also, this is an OBD1 block and Im running an OBD2 valve cover. Is there any special or fancy way for me to block off the PCV hole in the VC?
thanks in advance
Old Jun 16, 2007 | 08:25 PM
SD_Lurker's Avatar
HT White Ops
Default Re: LS Breather/Catch Can Question (slambedcivic)
Here this tells you everything!
https://honda-tech.com/zerothread?id=1199935
Old Jun 16, 2007 | 08:49 PM
that helps a lot! thanks.
is it necessary to remove both plugs and add the honda fittings to run the can, or can i just use one? i dont see a point in 2 really.
and also what about the valve cover hole?
Old Jun 16, 2007 | 09:04 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slambedcivic &raquo;</TD></TR><TR><TD CLASS="quote">that helps a lot! thanks.
and also what about the valve cover hole?</TD></TR></TABLE>
More fittings equals more venting.
Old Jun 17, 2007 | 05:23 AM
blackeg's Avatar
Default Re: LS Breather/Catch Can Question (Tippyman)
plug up #3.
remove #1 and the other plug on the other side of the oil filter. run your ventilation from them.
you can plug up #2, its a 1/8 bspt if im not mistaken, same as oil pressure sensor.
you can just leave the valvecover vent open, or get a little filter to put on there. thats what i did for my lsvtec running an obd1 block
Old Jun 17, 2007 | 06:42 AM
Default Re: LS Breather/Catch Can Question (blackeg)
the valve cover already has a breather on it. the one that i need to plug on the VC is where the PCV used to be. its an obdII VC.
Old Jun 17, 2007 | 10:10 AM
b16a4's Avatar
yeah i want to know as well
Old Jun 17, 2007 | 12:24 PM
HamiltonRex's Avatar
i only opened up port #1 not both its not nessecary.
Old Jun 17, 2007 | 01:09 PM
valve cover hole... what do i do with it?
Old Jun 18, 2007 | 05:08 PM
i need to know about the valve cover hole where the PCV used to be
Old Jun 18, 2007 | 05:23 PM
notfastenough's Avatar
get one of those small breather filters from autozone and put it on there.
Old Jun 18, 2007 | 05:44 PM
jewjew bean's Avatar
Default Re: LS Breather/Catch Can Question (notfastenough)
The best way in my opinion is:
1. leave the black box and and connect it to the IM like stock so your pcv system is intact and functional when not in boost.
2. reinstall the driver side plug and use the pass. side for your catch can.
3. since you have a newer valve cover with the grommet on top, hollow out the pcv valve and T it off to the breather can or if you have two bungs on the breather, have a separate line for the hollow pcv valve,
4. Leave the breather pipe on the valve cover exposed or attach a breather filter.
Old Jun 18, 2007 | 05:58 PM
HybridKOOP's Avatar
Default Re: LS Breather/Catch Can Question (mustafa)
Why would you want to PRESSURIZE the crankcase when in boost? You're defeating the purpose by running any type of line from/to the vent system to/from the intake manifold.
Old Jun 18, 2007 | 08:15 PM
Default Re: LS Breather/Catch Can Question (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">Why would you want to PRESSURIZE the crankcase when in boost? You're defeating the purpose by running any type of line from/to the vent system to/from the intake manifold.</TD></TR></TABLE>
im assuming you are talking to the last guy that posted. and on a side note, ive gotta LS crank that im pretty sure is still good. ill look at it thursday when i get to the shop.
altho his idea about hollowing out the PCV and running it to the catch can line is genius!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notfastenough &raquo;</TD></TR><TR><TD CLASS="quote">get one of those small breather filters from autozone and put it on there.</TD></TR></TABLE>
i would not be building engines if i didnt already know this... im not being a dick but that has been the answer that i was NOT looking for. i was looking for the PCV hole on top of the VC. you just seem to be the first person i brought out. sorry if you misunderstood my question and thanks for the reply
Old Jun 18, 2007 | 08:33 PM
5thgen's Avatar
Mine has been left open for the past 2 years......it will vent pretty much only air. I don't remember ever seeing any oil flying out. The worst thing that it has done is get a 3 inch circle of the underhood dirty.
Old Jun 18, 2007 | 08:46 PM
SwappedTURBOegg's Avatar
just run 2 fittings of rear of the block. and 2 off the valvecover. no pcv valve. leave teh breather open on the valvecover also
Old Jun 18, 2007 | 11:51 PM
it doesn't work like that. when in boost, the plunger in pcv valve closes.
Old Jun 19, 2007 | 03:43 AM
Default Re: (SwappedTURBOegg)
Come up with whatever answer suits you best. gl
Old Jun 19, 2007 | 04:54 AM
DrSeuss's Avatar
What normally goes in #2?
Old Jun 19, 2007 | 06:27 AM
Default Re: (DrSeuss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustafa &raquo;</TD></TR><TR><TD CLASS="quote">
it doesn't work like that. when in boost, the plunger in pcv valve closes. </TD></TR></TABLE>
the pcv is unreliable and will fail without notice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrSeuss &raquo;</TD></TR><TR><TD CLASS="quote">What normally goes in #2? </TD></TR></TABLE>
there is a brass fitting that goes in there. the second port on the black box connects there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notfastenough &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1199935
i do wanna keep the bay clean.
Come up with whatever answer suits you best. gl</TD></TR></TABLE>
thank you for your concern, and i greatly appreciate your help
HandMadeEgRHd
May 8, 2010 06:29 PM
incubusboy87
Aug 13, 2007 09:02 PM
slambedcivic
Jun 16, 2007 09:28 PM
StatGSR
Mar 1, 2005 10:05 AM
