are these precision injectors?
Old Jun 15, 2007 | 11:28 AM
ridin98civic's Avatar
Default are these precision injectors?
i purchased these injectors on ebay. seller said they were brand new precision 440's. just wanna make sure i didnt get scammed.
Old Jun 15, 2007 | 12:35 PM
mike1114's Avatar
Default Re: are these precision injectors? (ridin98civic)
2 seconds worth of googling........all I did was search for the part number.
Lucas 42.5# Disc injector. What we commonly call the 009 injector. Also, this injector can come with a light blue band or stripe as well. Just depends on the batch run that Lucas is doing. The other part number that you will/can see on these injectors are 01D0308.
Hope this helps.
Patrick
Precision Turbo & Engine
Old Jun 15, 2007 | 12:54 PM
Default Re: are these precision injectors? (mike1114)
so they are lucas 440's not precision 440's?
Old Jun 15, 2007 | 12:56 PM
mike1114's Avatar
Definitely not precision.
Precision etches the part number into the injector.
Old Jun 15, 2007 | 12:59 PM
thanks
Old Jun 15, 2007 | 01:11 PM
SPOOLINmatt's Avatar
precisions are usually blue on top in those body styles, but some oem cars have the same inj body as precisions. theres only so many types.
Old Jun 16, 2007 | 01:05 AM
one more question regarding these injectors. do i need to buy the rc clips? or can i just use obd1 honda clips?
Old Jun 16, 2007 | 02:35 AM
TURBODC4TEG's Avatar
nope sure aren't they are black with a gray bottom and the new ones have a precision sticker on them
Old Jun 16, 2007 | 10:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">one more question regarding these injectors. do i need to buy the rc clips? or can i just use obd1 honda clips?</TD></TR></TABLE>
Old Jun 18, 2007 | 09:10 AM
obd1, gotta shave the tab on the inside of the injector where the plug goes, youll see it, i usually use a sharp flat head and heat it with a lighter and shove it down in it and it shaves it nicely.
Old Jun 18, 2007 | 09:16 AM
SovXietday's Avatar
Default Re: are these precision injectors? (SPOOLINmatt)
OBD1, or you can also use the clips from an RS/GS Eclipse, they will just clip right on.
Definitely not "new" precisions. Precision has a sticker on all of there new ones.
TylerB
Feb 22, 2010 03:51 PM
98-0688
Aug 31, 2004 12:00 PM
specie
Oct 9, 2002 02:39 PM
