hondatas300 prob?
Old Jun 12, 2007 | 06:19 PM
THEDirtyDseriesWOOT's Avatar
Default hondatas300 prob?
i put a new head gasket on and i turn the key on and i get the vtec spool code so i hook a wire to the solenoid and hit it on the 12volt yah it clicks so i run a new wire to the ecu... still nothing.. so its not the solenoid its not the wire.. maybe ecu??
i have vtec oil pressure sensor disabled in the prefrences.. anyone got a idea or had this prob
Old Jun 13, 2007 | 05:43 AM
Turbo-charged's Avatar
Default Re: hondatas300 prob? (THEDirtyDseriesWOOT)
dissable vtec spool also
Old Jun 13, 2007 | 06:19 AM
tony1's Avatar
Default Re: hondatas300 prob? (Turbo-charged)
Have you checked the wire from the ecu to the solenoid? Could have an open wire or a short.
Old Jun 13, 2007 | 06:36 AM
i ran a new wire just temp like through the window into the engine bay and hooked it up directly .. still nothing..
where do you disable vtec spool in s300 software?
i disabled vtec all the way and its fine so i dont think its the ecu..
im gonna chage the solenoid out and clean the screen and stuff with a spare i have hopefully it does the trick .. it click but i dont have a multi meter so it might be bad..
Old Jun 13, 2007 | 06:38 AM
if the solenpid doesent work im gonna re pin d4 on the ecu maybe its not getting a good connection
mitchh29
Mar 13, 2013 12:23 PM
IVAN93EG
Jun 18, 2006 07:02 PM
ls weez
Jun 10, 2006 09:53 PM
mr. carpenter
May 5, 2004 09:47 PM
