idle problem after turbo.
Old Jun 15, 2007 | 10:54 AM
juice91si's Avatar
Default idle problem after turbo.
hey everyone, i recently swapped in a semi built a6 and turbocharged it.
when the car reaches operating temperature, the cel will flicker once, and then the idle will bounce between 1-2k.
when i unplug the map sensor, and the cel stays on, it will idle at 1100rpm, with no signs of an erratic idle.
ive been told i have a vacuum leak, so ive been trying to find it, will a vac leak only show once it reaches operating temp? is that possible?
i have a hondata im gasket, and a d16y8 im, and have all of the nipples properly blocked off, or have a vac hose on tight with a ziptie.
have checked everywhere for a leak, i just replaced my tb gasket last night (which i thought may be the cause) but it still does it.
i tried my stock ecu for a sec to see if it does the same thing, and it does.
i bled my coolant twice, and have no air bubbles.
is my map sensor bad?
what could cause the problem to only appear when the engine is warm?
Old Jun 15, 2007 | 07:39 PM
gd99em1's Avatar
Default Re: idle problem after turbo. (juice91si)
i believe if you don't have your bov set right it can cause idle problems
Old Jun 15, 2007 | 09:51 PM
juice91si's Avatar
Default Re: idle problem after turbo. (gd99em1)
i did have my bov coming from the tb, and it was fluttering. i hooked it up to a better vac source, and now its perfect, so the bov is fine.
anyone else?
Old Jun 16, 2007 | 06:16 AM
shortyz21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gd99em1 &raquo;</TD></TR><TR><TD CLASS="quote">i believe if you don't have your bov set right it can cause idle problems</TD></TR></TABLE>
i dont think so.
Old Jun 17, 2007 | 02:29 AM
juice91si's Avatar
Default Re: idle problem after turbo. (shortyz21)
Old Jun 17, 2007 | 04:19 AM
g23_ej1's Avatar
what kind of fuel and management are you running?
Old Jun 17, 2007 | 03:05 PM
juice91si's Avatar
Default Re: idle problem after turbo. (g23_ej1)
superchips chipped pm6
Old Jun 17, 2007 | 03:21 PM
HamiltonRex's Avatar
your warm idle is too rich.
Old Jun 17, 2007 | 03:26 PM
juice91si's Avatar
how do i adjust that?
cuz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juice91si &raquo;</TD></TR><TR><TD CLASS="quote">
i adjusted my valves. made sure my intake manifold bolts were tight, and rechecked all of my vacuum lines and its all good. more ideas? im gonna try replacing my map sensor. in the next few days.
sohcpower1
May 22, 2016 10:09 AM
giomfe
Jul 9, 2007 06:11 AM
Topdawgg
May 13, 2007 05:07 PM
boostin1cam
Jul 20, 2005 05:39 PM
allmotaEM1
May 19, 2005 09:59 AM
