TOGA Oil Pump?
Old Jun 16, 2007 | 02:55 PM
maddog20's Avatar
Default TOGA Oil Pump?
I was wondering if anyone has any experiance with this oil pump?
There has been numerous failures with the 96-00 SOHC oil pump and I was wondering if this would resolve this issue.
Thanks
http://www.autoperformancewarehouse.com/toga.html
Old Jun 16, 2007 | 07:29 PM
HiProfile's Avatar
Default Re: TOGA Oil Pump? (maddog20)
I've personally seen 96-00 crankshafts against D16Z6 cranks, and the diff is less hole chamfering on the Y7/Y8 cranks, and the Y7 cranks I've seen had their oil passages drilled odd - the journals were not crossdrilled, meaning oil was only being pushed onto one side of the bearing. I do know the Z6 crank I had balanced needed only 1 spot of material removed - it could be Honda got a little cheap and didn't balance the Y7/Y8's all that well, or I got a good crank.
I really don't think it is the oil pump to be honest. You can also mod the pump to remove restrictions and smooth the flow with a grinder and devcon epoxy to help with 7k+ rpm's.
Old Jun 16, 2007 | 07:40 PM
maddog20's Avatar
Default Re: TOGA Oil Pump? (HiProfile)
Ok, I had benson balance and polish the crank so I should be good?
Old Jun 17, 2007 | 09:27 AM
miro_gt's Avatar
port out your Y7/Y8 oil pump according to .theoldone.com
Old Jun 17, 2007 | 07:09 PM
JDMvirginNC's Avatar
Default Re: TOGA Oil Pump? (miro_gt)
Im runnin a TOGA HV fuel pump on my built turbod d16y7 and I have had no trouble with it..It is a pretty well machined oil pump and seemed to be of good quality!
Old Jun 17, 2007 | 07:24 PM
THEDirtyDseriesWOOT's Avatar
i spubn a bearing with the old one type oil pump that was also shimed for more pressure.. i now use the toga pump on my d and rev to 9 k all day long
Old Jun 17, 2007 | 08:24 PM
Laserjock's Avatar
Default Re: (THEDirtyDseriesWOOT)
How many miles on the engine and pump?
Good to know. I'm in the process of finding an engine builder. I have in my posession a Z6, Y7, and Y8 crank. I'll get some pics up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMvirginNC &raquo;</TD></TR><TR><TD CLASS="quote">Im runnin a TOGA HV fuel pump on my built turbod d16y7 and I have had no trouble with it..It is a pretty well machined oil pump and seemed to be of good quality! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEDirtyDseriesWOOT &raquo;</TD></TR><TR><TD CLASS="quote">i spubn a bearing with the old one type oil pump that was also shimed for more pressure.. i now use the toga pump on my d and rev to 9 k all day long</TD></TR></TABLE>
Old Jun 18, 2007 | 06:48 PM
Laserjock's Avatar
Default Re: (Laserjock)
How many miles on those engines and pump?
Old Jun 19, 2007 | 07:25 PM
Freshly built motor ~2 oil changes!
FairlyImprudent
Sep 4, 2013 10:13 AM
wickedplastikman
Feb 20, 2009 02:40 PM
Chris_Spires
Oct 6, 2008 03:34 PM
BlendedEJ8
May 31, 2003 11:22 AM
PROFILES2000
Feb 25, 2002 01:17 PM
