pistons
Old Jun 12, 2007 | 10:13 PM
1993gsrcivic's Avatar
Default pistons
i have a gsr and i need rings its all stock internals and i want to turbo at the end of the summer i was going to just put new pistons in while it was apart i was wondering what would be better for turbo
Old Jun 12, 2007 | 10:19 PM
tony413's Avatar
Default Re: pistons (1993gsrcivic)
any piston with a dish construction
Old Jun 12, 2007 | 10:22 PM
numbnuts22715's Avatar
The brand depends on what kind of money you wanna spend.
CP Pistons are what I'm going to get, cause of my engine builders recommendation. Also, through reading on HT, people have said the clearances are better. Although it doesnt really matter if you do the machining after you get the pistons, it would still be easier, in my eyes, to just get the CPs.
how much money are you looking to spend.
Old Jun 12, 2007 | 10:27 PM
Default Re: (numbnuts22715)
i know this sounds dumb but what are cp pistons?
Old Jun 12, 2007 | 10:29 PM
tony413's Avatar
LMFAO they are pistons but "CP" is the name of the company google it and check out there website also look up
arias
wiseco
endyne ( the old one ) roller wave will be the name of the pistons
Old Jun 12, 2007 | 10:33 PM
Default Re: (tony413)
thanks lol what kind of ratio do i want to get
Old Jun 12, 2007 | 10:40 PM
Default Re: (1993gsrcivic)
what size pistons fit a gsr wit stock bore
Old Jun 12, 2007 | 10:43 PM
are you sure you can use stock bore?
Have you had a machine shop take a look at it to make sure its all clean and nice?
Usually retailers will have what sized pistons your engine needs. Youll look at the list and some will say what engine they are for.
Old Jun 13, 2007 | 02:01 PM
tony413's Avatar
the stock bore is 81mm on all b-series motors and if you want to get a larger bore that involves sleeving or boring out the stock sleeves and the safest large bore to run on a boosted b-series is 84.5mm
Old Jun 13, 2007 | 02:43 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">the stock bore is 81mm on all b-series motors </TD></TR></TABLE>
not all
Old Jun 13, 2007 | 03:18 PM
Default Re: (doood)
whats a good boost ratio?
Old Jun 13, 2007 | 03:48 PM
tony413's Avatar
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
not all </TD></TR></TABLE>
haha ok ok fine the B20's are the only blocks with a stock 84mm bore happy now.
to OP there isnt a boost ratio unless you meant compression ratio and for that it varies on what you want and need goal wise.
Old Jun 13, 2007 | 09:51 PM
i was wondering if i need a high compression or low compression piston what one will be better for turbo
Old Jun 13, 2007 | 10:04 PM
low compression is better for turbo.
Higher compression can be turbo'd just fine, but theres less of a safeguard with it. high compression is more prone to detonation if I'mt hinking correctly.
you can go with 9.5:1 or so, something around there. That way it'll have nice drivability out of boost, and in boost.
Old Jun 14, 2007 | 10:07 PM
so high compression wit turbo is more likely to crack the block? so low compression is safer
Old Jun 14, 2007 | 10:09 PM
yes, low compression is safer.
Also, lower compression can often yield higher boost numbers, even though it doesnt really matter.
Old Jun 14, 2007 | 11:28 PM
tony413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993gsrcivic &raquo;</TD></TR><TR><TD CLASS="quote">so high compression wit turbo is more likely to crack the block? so low compression is safer</TD></TR></TABLE>
it wont exactly crack the block but it can crack te sleeves if pre-ignition or detenation occurs. and anywhere from 8.8 to 10.0 is fine for boost. but think about this also rising compression also rises temperature in the motor as does the turbo and heat is a factor that can cause pre-ignition so because as to not run alot of boost on a 10:1 motor i believe 15psi is very acheivable but requires correct tuning and fuel supply.
Old Jun 15, 2007 | 01:23 PM
http://cgi.ebay.com/ebaymotors...photo
so this would be ok pistons for boost
is this the dish shape you was talking about
Old Jun 15, 2007 | 03:01 PM
doood's Avatar
if you're going to spend money on pistons at least get forged ones. they're lighter, stronger, and will handle the abuse better.
Old Jun 15, 2007 | 03:25 PM
agrn93ls's Avatar
Default Re: pistons (doood)
WOW where's the search police on this one.
any way the compression ration you want needs to be based on what your driving style is and overall power goal is.
anything from 8.5-9.5 is generally a good idea
i went with around 10 because i like some compression but i am not goin for godzilla power im goin for fun and drivability close to stock at low rpm.
anyway i like wiseco pistons i dont really read anything bad about them, know NUMEROUS people using them and the best tuner i know suggested and uses them.
and i have wiseco pistons so i might be a little biased. CP's are bad *** but with the prior history i am weary even if the problem has been fixed
kennie555
Feb 21, 2013 04:32 PM
ge_itr
Feb 5, 2007 06:45 PM
masteryoda10
Jan 30, 2006 04:30 AM
