Wastegate questions
Old Jun 12, 2007 | 10:25 PM
Lightweight Boost's Avatar
Default Wastegate questions
quick and easy questions for everyone
do alot of people run an external wastegate with an internally gated 14b ? also , around how many psi does rthe 14b make stock ? if its under 11 i wont worry about it but if it boost more than ill have to go with the motorola 3 bar map , i have . i know the stock map is good until 11.6-12 lbs , just curious . oh yeah , z6 bottom , y8 head is the engine if anyone cares . yeah 11lbs is a lot for stock but cant live life in fear (read: i have a backup engine just in case )
Old Jun 12, 2007 | 10:47 PM
numbnuts22715's Avatar
usually people wont convert over from an internal wastegate to an external.
That turbo is pretty small...
From what I've gathered through searching, stock wastegate is anywhere from 8-10 lbs.
Is it from an eclipse/ talon?
Old Jun 13, 2007 | 06:23 AM
Default Re: (numbnuts22715)
yeah its small but for the 14b and stock bov im paying 100.00 and that puts me at having an almost complete turbo kit minus clutch and oil lines for around 125.00 yeah its a 1g eclipse turbo . from what ive searched the gate leaks boost but the guyim getting it from says it didnt and i can trust him but later on it might and i just want to be prepared .
Old Jun 13, 2007 | 08:30 AM
also, for a lot of the mitsubishi turbos, its possible to get upgrades for the wastegate's and everything.
Theres a guy at SlowBoy Racing.. I think his name is chris... He's a really helpful and cool guy. You could talk to him abiout upgrading the wastegate later.
Hope that helps.
Old Jun 13, 2007 | 08:58 AM
thanks ********
Old Jun 13, 2007 | 09:11 AM
RubenPrelude's Avatar
My 14b internal wastegate opens at 6-7 psi
Old Jun 15, 2007 | 05:54 PM
heres the news just recieved turbo today and the exhaust housing has a crack in it . i have a guy that can weld up the crack and we were talking about welding up the spot where the flapper is , where would you miount the wastegate if i went external . i am using a civic hx manifold as a means for turbo manifold thanks
Old Jun 15, 2007 | 06:06 PM
you would mount the external gate to the turbo manifold... you need a wastegate port.
Old Jun 15, 2007 | 09:10 PM
there is not going to enough room on th hx manifold though , i tried to search but to no avail
Old Jun 16, 2007 | 12:07 AM
so youre using like a regular exhaust manifold?
I dont think that's gonna work... Buy a cheap log manifold.
Old Jun 16, 2007 | 02:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">so youre using like a regular exhaust manifold?
I dont think that's gonna work... Buy a cheap log manifold.</TD></TR></TABLE> but its free and the guy doing it for me is really smart , like airplane mechanic smart
Old Jun 23, 2007 | 02:12 PM
88redrex's Avatar
Default Re: (Lightweight Boost)
instead of welding the flapper hole shut, weld a section of pipe there, then put an external wastegate flange on the end of the pipe and mount the wastegate. You can pretty much run it where ever you want in the engine bay too
cliff666
Mar 15, 2006 09:46 AM
KURUPTinc
Jul 12, 2005 01:04 PM
1.8T_EG
Sep 20, 2002 03:44 PM
