Does this seem right for power???
Old Jun 18, 2007 | 07:25 PM
SinglecamMitch's Avatar
Default Does this seem right for power???
STD Vatara Pistons
Eagle Rods
Arp rod bolts
Arp Head Studs
OEM Honda Head Gasket
Ported Head
Skunk2 Intake Manifold
680cc Injectors
Ported LS Throttle Body
2.5" IC piping
Big FMIC
T3/t04 60 trim AR.48 Turbo
Custom Ram Turbo Manifold
255hp Fuel Pump
Dual Core
Full 3" Exhuaust
3 Bar MAP
Thats my build and went to get it tuned... well at 10 psi i only made 170 whp.... is this normal... i got a 1bar spring coming but was curious if there is something wrong with my setup... i thought it would make more power at that boost level...
The manifold is designed for a b-series but i drilled it out to fit my d... ports line up pretty decent tho... Let me know what it could be???
Old Jun 18, 2007 | 07:26 PM
Turbo-charged's Avatar
Default Re: Does this seem right for power??? (SinglecamMitch)
made 273whp @ 11psi on a gt28 yesterday
Old Jun 18, 2007 | 07:27 PM
slowsol95's Avatar
that is terrible power for your set up, why did you cheap out at the last minute on the manifold? it probably flows like ****. get a manifold made for that head and see what it does for you.
Old Jun 18, 2007 | 07:28 PM
Boilermaker1's Avatar
That seems way low... I was making more than 180 on a GT28 at 6 psi.
What was reading boost? First time I had it tuned, my gauge was reading 10, but the dyno was reading the vac line to the BOV, which turned out to be leaking and it was only actually making 5.5... why the difference, I dont know.... but I'd start looking for a boost leak.
Old Jun 18, 2007 | 07:32 PM
Default Re: (Boilermaker1)
there was no boost leaks but i do believe its in the manifold...
Old Jun 18, 2007 | 07:35 PM
if your tuning a car, you sould be using nothing other than the MAP sensor (data logging) to determine what the boost level is.
most gauges are crap. hell the tach in my car is 1000 rpm off at 10500 rpm.
@ 38 psi the boost gauge swings beween 35 and 45-50 like the needles going to break off.
i cant count how many cars ive done where the boost gauge reads one thing, the boost controller reads another, and the map sensor is another number.
Old Jun 18, 2007 | 07:37 PM
Chris Tune's Avatar
Default Re: (Turbo-charged)
i've seen that with the gauges and the boost controllers way too many times too... map is the only way to read boost pressure
Old Jun 18, 2007 | 07:40 PM
well its a small blue spring in the wastegate... 9.5psi i believe and we hooked up two seprate gages and both were within a psi
Old Jun 18, 2007 | 07:57 PM
ill pull my manifold off tomorrow and line the gasket up and see how far off my holes are... its should tell me if thats the reason for such low numbers... and the only reason i ran this manifold is b/c i had a similar setup before and it cooked
boosted_D
Mar 12, 2012 11:29 AM
8YourV8
Nov 29, 2010 03:47 PM
Powelly
Jan 19, 2009 05:32 PM
JDM94EG28
Oct 19, 2006 06:46 AM
turbosijuice
Jan 30, 2006 07:57 PM
