is my compression good to boost?
Old Jun 18, 2007 | 11:45 AM
89hatchy's Avatar
Default is my compression good to boost?
i just did a compression test and in cylinder #1 its 160. 2,3,and 4 are at 190. is it still okay to boost the greddy 15g at 12 pounds like this?? i keep getting mixed reviews. i double checked it, and its the same. no leaks, burned oil, and it runs like a champ.
Old Jun 18, 2007 | 06:45 PM
blackeg's Avatar
Default Re: is my compression good to boost? (89hatchy)
ah its borderline. leakdown and see where the compression is going. if its not the rings then you should be fine.
my motor last year's compression was 190.190.120.190 and it ran 12s and handled 18 psi fine the day i took it apart. it was also sleeved and fully built and dyno tuned, so take that into consideration too
GdmLaz
Jan 28, 2008 10:16 AM
chriskona
Sep 25, 2006 07:34 AM
TehMoonRulz
May 16, 2005 01:15 PM
xonn
Apr 10, 2003 10:55 AM
