SLS mini log EF fitment issues?
Old Jun 14, 2007 | 08:54 AM
-16V-'s Avatar
Default SLS mini log EF fitment issues?
Thinking about buying the mini log, but wondering if im going to run into any problems fiting it on my ef hatch.
Anyone run it on there EF?
TIA
Old Jun 14, 2007 | 09:50 AM
SD_Lurker's Avatar
HT White Ops
Default Re: SLS mini log EF fitment issues? (-16V-)
What motor?
Old Jun 15, 2007 | 04:37 AM
-16V-'s Avatar
Default Re: SLS mini log EF fitment issues? (SD_Lurker)
D16z6, my bad
Old Jun 15, 2007 | 04:49 AM
Autoworks's Avatar
will work fine with a 1/2 sized radiator
Old Jun 15, 2007 | 01:45 PM
thepariah25's Avatar
Default Re: SLS mini log EF fitment issues? (Autoworks)
i ordered two manifolds from them, shorty and ram manifolds for B-series engines. my order was smooth as was install, no problems. i recommend them. not sure about your application but make sure you dont screw yourself with piping issues, if this is a new set-up you might be alright but if your changing manifolds re-fabrication is always gonna be there for charge pipes/downpipe/dumptube.
Old Jun 15, 2007 | 08:12 PM
92HatchHybrid's Avatar
Default Re: SLS mini log EF fitment issues? (thepariah25)
Log should have no problems. Shorty Hangs it a bit low if you are running a front crossmember still.
Im sure you have read in having an EF that cross member is a pain makes any DP tight but with half radiator and Log you will be fine..
Old Jun 16, 2007 | 07:06 AM
wfocrx's Avatar
I have the mini log kit in my d16z6 crx. Iam running a 1/2size radiator and full race traction bar. the dp clearance is fine, the dumptube though has like 1/8th" clearance with my rad fan and its a thin electic one. overall, Iam happy with it, although it took like 2 months to get it
Old Jun 17, 2007 | 07:09 PM
-16V-'s Avatar
Default Re: (wfocrx)
Cool,
Thanx for the quick positive replies.
disfilam04
Dec 8, 2017 04:25 PM
1990si
Feb 14, 2010 08:20 AM
civicdust
Apr 22, 2009 09:43 PM
Nerologic
Nov 5, 2003 10:44 PM
