pte vs rc 1000cc injectors?
Anybody tried both rc and precision 1000cc injectors? Perhaps tuners could chime in...
Any pros/cons of each?
Idle quality/spray pattern differences between them?
Is one easier to set up (tune) than other?
Any fuel pressure limitations/requirements to one vs the other?
Reliability/quality issues?
I already know that I can get precisions a little cheaper, but are the rc's any better?
thanks in advance for all/any comments!
Re: pte vs rc 1000cc injectors? (markaria)
I have used both injectors before on many set-ups and I have come to the conclusion that I get similar results with both injectors. I spoke to Tony about this subject and if I recall correctly I think he noticed that he was able to get a smoother/more consistant idle with the RC's. Maybe he'll chime in.... so don't quote me on this.
On the precision injectors I recommend leaving the o-rings on the end of the injectors so that all injectors have a uniform spray angle. Again, both injectors are great and I have used both injectors flawlessly on many 500+whp daily driven set-ups.
Re: pte vs rc 1000cc injectors? (PrecisionH23a)
I agree...similar results with both. I notice the RC a little laggier at idle, but nothing that would drive you nuts.
As long as the sets are clean and matched properly, you should be good to go with either brand
