** BLOX PRO 1 CAMS Vs. SKUNK2 PRO 1 CAMS **
Blox has the new pro 1 copys out now.Was reading the thread on how the skunk 2 pro 1's made 40 hp more compared to itr cams.So my question is how are these blox cams comparable to the skunk2 pro 1's In a turbo car as in lift,duration etc..Any help is appreciated.
Re: ** BLOX PRO 1 CAMS Vs. SKUNK2 PRO 1 CAMS ** (IT'S ME DAVID)
Read the other post more carefully, the Pro 1 cams made 40 more hp at 3psi less boost, that's more like 80whp.
Do a back to back test with the blox cams and let us know how it works out.
Re: ** BLOX PRO 1 CAMS Vs. SKUNK2 PRO 1 CAMS ** (Fitti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti »</TD></TR><TR><TD CLASS="quote">if the blox are an exact copy I would think you would see similar results.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti »</TD></TR><TR><TD CLASS="quote">if the blox are an exact copy I would think you would see similar results.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti »</TD></TR><TR><TD CLASS="quote">if the blox are an exact copy I would think you would see similar results.</TD></TR></TABLE>
Re: ** BLOX PRO 1 CAMS Vs. SKUNK2 PRO 1 CAMS ** (Boostfed.com)
if theyre exact copies then why compare them???same base circles, same lift, same valve speeds,same duration at .010, .020, .030,.040....you see my point????only thing that would make a change in anything at this point is lobe seperation....
Re: (sheepey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepey »</TD></TR><TR><TD CLASS="quote">if theyre exact copies then why compare them???same base circles, same lift, same valve speeds,same duration at .010, .020, .030,.040....you see my point????only thing that would make a change in anything at this point is lobe seperation....</TD></TR></TABLE>
The real question is are they the same or is it a hondatech rumor?
Re: (Boosted Chemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">
The real question is are they the same or is it a hondatech rumor?</TD></TR></TABLE>
Exactly. The whole point is to confirm they are the same and make the same power.
Both should come with spec sheets which should make it easy to verify if they are exact copies.
exactly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsi-t »</TD></TR><TR><TD CLASS="quote">test it up </TD></TR></TABLE>
exactly
Re: (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">Materials are the same, but they are not duplicates. Blox copied the proto-type not the production cams.</TD></TR></TABLE>
Okay so what is the difference between the prototype and production cams?
Seems to me that blox is just another SSAuto that knocks off everybodys ****, they just don't have the name that SSAuto has. Every part blox has is a knock off of a successful part.
Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Seems to me that blox is just another SSAuto that knocks off everybodys ****, they just don't have the name that SSAuto has. Every part blox has is a knock off of a successful part. </TD></TR></TABLE>
Tough **** bro, that's how the world works.
Microsoft knocked off Apple who knocked off Xerox. And these are huge companies...if it's happening at that level you better believe it's going to happen in the import performance world too.
Up until the Pro series cams came out almost every cam manufacturer (junk2 included) was stealing JUN's VTEC lobe for one of their cams, I never hear people bitch about that.
If someone out there can make your product the same quality/better for cheaper, than tough luck.
Don't hate the player, hate the game.
Re: (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">
Don't hate the player, hate the game. </TD></TR></TABLE>
Ram horn style turbo manifolds were originally done by Kook's Exhaust and also AXZ out of NY waaaay back in the day, they justy did not use the extra thick SS now used by everyone
It's one thing to be a player in a market, developing your own things, working off of what's available. Comparing Apple and Mircrosoft is a bit different than what we're talking about.
I know there's nothing you can do, but i won't support these knock off companies in any way. They come out of nowhere and the only products they offer are knock offs. No development work at all. I support those who do the research and development.
You don't have to agree, doesn't really matter to me.
