Running a mustang throttle body- What TPS?
I currently have a f-r intake manifold and I have in my possesion a BBK 75mm mustang throttle body. Now, I have accomplished getting the throttle cable to work. Now I need advice on what to do about the TPS. Im pretty sure the OEM Honda TPS will not work. I have contemplated running a Mustang TPS, but I dont know if Hondata will accept it. I know they are both 3 wire TPS with a 5v signal. I am looking for advice from SOMEONE WHO HAS RUN IT.
Modified by 1Bar GSR at 8:52 PM 6/14/2007
Re: Running a mustang throttle body- What TPS? (1Bar GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Bar GSR »</TD></TR><TR><TD CLASS="quote">I currently have a f-r intake manifold and I have in my possesion a BBK 75mm mustang throttle body. Now, I have accomplished getting the throttle cable to work. Now I need advice on what to do about the TPS. Im pretty sure the OEM Honda TPS will not work. I have contemplated running a Mustang TPS, but I dont know if Hondata will accept it. I know they are both 3 wire TPS with a 5v signal. I am looking for advice from SOMEONE WHO HAS RUN IT. </TD></TR></TABLE>
Like I told you on AIM, get it to read .49 volts (I think) at idle or closed and then 4.5 volts at WOT! Adjust it damnit, many people have it and have done it, its gotta work. If I am wrong then hit me with the
Re: Running a mustang throttle body- What TPS? (Boostfed.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">Like I told you on AIM, get it to read .49 volts (I think) at idle or closed and then 4.5 volts at WOT! Adjust it damnit, many people have it and have done it, its gotta work. If I am wrong then hit me with the </TD></TR></TABLE>
You didnt tell me that on AIM you LIAR! You probably copied and pasted that from somewhere
You didnt tell me that on AIM you LIAR! You probably copied and pasted that from somewhere </TD></TR></TABLE>
I did and deleted our converstion to prove you wrong Dick
Ok, you might be right, but you told me to ask the masses! So I did...
"If you ask them questions, answers will come!"
Kinda like field of dreams
If you have S300, you can rescale the TPS. If you have s100/S200, you have to make the sensor read like stock, just like boostfed said.
Re: Running a mustang throttle body- What TPS? (Turbogixxer)
I'd would be curious to see this working on a s300 setup as well. I have a FR IM but i'm still using a stock TB.
Re: Running a mustang throttle body- What TPS? (sp00led)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00led »</TD></TR><TR><TD CLASS="quote">I'd would be curious to see this working on a s300 setup as well. I have a FR IM but i'm still using a stock TB.</TD></TR></TABLE>
It works, I have used it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">If you have S300, you can rescale the TPS. If you have s100/S200, you have to make the sensor read like stock, just like boostfed said.</TD></TR></TABLE>
Yeah my tuner told me the same thing yesterday
LSVTEC 91 Civic
15
10-28-2005 06:16 PM
