lsvtec turbo build help
Old Jun 12, 2007 | 07:44 PM
J_trizz's Avatar
Default lsvtec turbo build help
im building an lsvtec b18b block with a gsr head an i wanna go turbo.
can i use my ls pistions out of my ls block ? An what would be the best
ecu to use for the build
Old Jun 12, 2007 | 08:15 PM
Redline130's Avatar
Default Re: lsvtec turbo build help (J_trizz)
If you can afford it, I would use stronger aftermarket rods and pistons.
As for an ecu choice, I would suggest doing some research into the different types and brands that are out there. There really isn't a "best" ecu for any given application. Your budget will play a big factor into what system you will get. Also, who will be tuning your motor? Choosing a system that you or your tuner is most comfortable working with should be a big consideration in choosing what system you pick.
Old Jun 12, 2007 | 08:44 PM
carcala's Avatar
Default Re: lsvtec turbo build help (Redline130)
i agree! find out who will be tuning ur car and what system he is most comfortable with ex.hondata, crome, aem etc.. also if this is a budget build u should be ok with the stock pistons. i would recomend using some arp fasteners like rod bolts and headstuds. what turbo setup are u using??
RELLiK509
Sep 26, 2012 04:48 PM
beyondstock
May 14, 2009 11:34 AM
alexm
Nov 26, 2007 01:51 AM
Imprezor
May 16, 2005 06:35 PM
VoltageLS
Feb 2, 2003 05:04 PM
