Oil restrictor on Turbonetics turbo
Old 06-16-2007, 06:09 PM
bubbleboy22's Avatar
Default Oil restrictor on Turbonetics turbo
i have the old drag turbonetics turbo and it leaking oil... i got the ATP oil restrictor but the oil inlet on the turbo is to "deep" and the restrictor isnt long enough . Does anyone kno another oil restrictor i can get? thanks
Old 06-16-2007, 07:14 PM
HiProfile's Avatar
Default Re: Oil restrictor on Turbonetics turbo (bubbleboy22)
NPT-AN fitting, solder, flux, torch. Heat the fitting after applying flux inside it, get it to >500F, then fill it half way with solder. Drill a 1/16" hole in it, and you're done. Disclaimer - if you burn yourself, you're a retard.
Since oil never reaches temps to melt solder, it will always be fine - assuming its not the fitting in the turbo. I usually put it on the far side of the oil line (inlet to oil line, far from turbo), so it never gets any heat from the turbo.
Old 06-16-2007, 09:18 PM
SPOOLINmatt's Avatar
Default Re: Oil restrictor on Turbonetics turbo (HiProfile)
you really shouldnt have to use a restrictor according to turbonetics website. they come with some filter screen fitting now, i dont know if its a restrictor or not though.
Old 06-17-2007, 09:49 AM
Default Re: Oil restrictor on Turbonetics turbo (SPOOLINmatt)
yea i heard that also but i have an older turbo.
Old 06-18-2007, 03:26 PM
bump....to the top
blk96coup
07-28-2008 11:33 AM
Anti-Drama Queens
12-05-2006 04:28 PM
jacob_kohler
09-17-2004 12:44 PM
z6
06-03-2004 11:03 AM
Ri5e
06-20-2002 10:41 AM
Quick Reply: Oil restrictor on Turbonetics turbo
