ebc question
Old Jun 13, 2007 | 08:39 AM
powerdbygarrett's Avatar
Default ebc question
im thinking of getting an hks ebc for my build and had a question about it before i buy it. i know on the hks ebc there is a selection for low boost and high boost. is there any way i can have two tunes for the low boost and high boost? what i mean is drive around daily on low boost and then switch to high boost but i want it tuned? does anyone else do the same thing?
Old Jun 13, 2007 | 08:51 AM
numbnuts22715's Avatar
I'm pretty sure that if you have a certain amount of boost tuned, anything lower than that boost level will be tuned as well...
So if you have it tuned for 20 psi, then anything less than that will be safe to drive around on.
Old Jun 13, 2007 | 09:15 AM
twkdCD595's Avatar
Default Re: ebc question (powerdbygarrett)
as said above... tuner will tune it to the highest boost pressure your going to run... in doing so he will have to tuned everything below that pressure, which this will allow you to run anything under the max pressure tuned obviously.
just make sure you pick a good tuner now, and if you worried about it still just ask them about it to reassure yourself.
Old Jun 13, 2007 | 09:27 AM
Bonestock98GS's Avatar
Default Re: ebc question (twkdCD595)
xx2 good info guys they are right. Upon doing my research I found out the exact same thing about low boost and high boost settings. Good Luck
Old Jun 13, 2007 | 11:14 AM
awesome. thanks a lot for the info
Old Jun 13, 2007 | 11:16 AM
is there anything better then the hks ebc out there for about the same price? just wana have some options open
Old Jun 13, 2007 | 11:35 AM
If I were you, I would talk to the person uning your car.
Sometimes they have a preference with what they tune with.
I know a lot of people like the hks, and I also know poeple like the e-01.
teddy_dc2
Aug 6, 2006 07:10 AM
aalb1
Nov 15, 2005 02:09 PM
The Poopsmith
Dec 14, 2002 01:35 PM
Integra187
Sep 21, 2001 07:13 PM
