before tunning
Old Jun 12, 2007 | 05:35 PM
ericstambaugh07's Avatar
Default before tunning
im getting my boosted prelude tunned in a week..and i was jw what everyone does to there car before being dyno tunned.?.what i am going to do it..
new o2 sensor
new plugs
it has new oil it it..about 1 mile on it
new dist. cap and rotor
it has brand new wires
Old Jun 12, 2007 | 05:56 PM
Bailhatch's Avatar
Default Re: before tunning (ericstambaugh07)
o2 sensor should be disabled when tuning so a new one wont help anything.
make sure the front tires are in good shape and properly inflated. check ball joints and bushings, tie rods, lug nuts etc.
make sure you have plenty of whatever fuel you are running
pressure test your whole setup from the turbo inlet to the head to well over the boost you may run.
clean out your interior just as a courtesy to the tuner. no one wants to sit next to your 2 day old mcnuggets a full ashtray for 4 hours.
set base timing
bring a couple sets of extra plugs in whatever heat range(s) you might need
make sure there is no half *** wiring
fix exhaust leaks
bring more money than they told you and be prepared to spend it
make ecu accessible if needed to tune
-thats all i got right now-
Old Jun 12, 2007 | 06:08 PM
SPOOLINmatt's Avatar
Default Re: before tunning (Bailhatch)
Tuned, Not Tunned. Good luck.
Old Jun 12, 2007 | 06:09 PM
well i only have one o2 bung..and he said there has to be a o2 in it or the ecu will be thrown off
Old Jun 12, 2007 | 07:09 PM
Bailhatch's Avatar
what ecu?
Old Jun 12, 2007 | 07:24 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericstambaugh07 &raquo;</TD></TR><TR><TD CLASS="quote">well i only have one o2 bung..and he said there has to be a o2 in it or the ecu will be thrown off</TD></TR></TABLE>
Most tuners disable the o2 sensor and put in their own to tune the car.
I can't imagine anyone tuning with the stock one enabled.
Old Jun 12, 2007 | 07:26 PM
Tippyman's Avatar
If it's a chipped ECU with crome or something like that then it will likely have an option to disable the 02 sensor.
Old Jun 12, 2007 | 09:20 PM
PrecisionH23a's Avatar
tuning checklist:
http://www.evans-tuning.com/checklist.html
Old Jun 12, 2007 | 11:01 PM
FaceTuned's Avatar
Default Re: before tunning (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">tuning checklist:
http://www.evans-tuning.com/checklist.html</TD></TR></TABLE>
Old Jun 13, 2007 | 10:37 AM
Default Re: before tunning (FaceTuned)
up..anyone else?
Old Jun 13, 2007 | 10:46 AM
Turbo-charged's Avatar
http://www.tempestracing.net/tuningchecklist.html
Bad_dude
Apr 24, 2013 10:36 PM
charlie0801
Oct 15, 2007 05:50 PM
pinoy369
Feb 26, 2007 04:27 PM
civictunr_ls
Feb 23, 2005 03:19 AM
