Audible boost warning?
Old Jun 13, 2007 | 10:47 AM
trecool44's Avatar
Default Audible boost warning?
Does anyone know what to constuct a device that would sound an alarm when your boost level got to a pre-set level? I was thinking a relay with the map sensor hooked to the contacts and a buzzer on the coil. You could scale down the map sensor voltage with a pot for tunablility.
Old Jun 13, 2007 | 11:09 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Audible boost warning? (trecool44)
Like a "full boost" buzzer? That doesn't sound like a good idea to me. Your idea on how you could make it work, though, is very good Let us know how that turns out.
If you're wanting to use this for overboost protection, you could always use your standalone to set a boost-limiter and let the sound of the engine hitting the proverbial wall let you know to get out of it
numbnuts22715's Avatar
some electronic boost controllers do that.
My friends greddy profec does it. It beeps when you hit the "warning boost level" or something like that, but anyways, you set it. Its fully user adjustable.
Old Jun 13, 2007 | 05:13 PM
trecool44's Avatar
bump for answers
Old Jun 14, 2007 | 06:44 AM
jameelrose's Avatar
get a boost sensitive switch and hook it up to what ever device u want to use to warn you. the set the boost level u want the switch to activate at and your done. i don't see why this is needed, but its that simple. g/l
Old Jun 14, 2007 | 02:12 PM
dcg9381's Avatar
Lookup "hobbs switch"
All you need is a pressure sensitive switch.
Old Jun 14, 2007 | 02:25 PM
HiProfile's Avatar
Default Re: Audible boost warning? (dcg9381)
Hobbs switch and a piezio-electric buzzer is all you'd need, then set the hobbs switch to the preset limit. If you're looking for overboost protection, a pop-off valve is much better, although using this in combination would let you know what happened instantly.
Freshdot
Mar 14, 2011 10:35 AM
adam00
Engine Management and Tuning
Sep 1, 2009 05:49 PM
Blazin Civic
Apr 21, 2005 12:57 PM
philipwight
May 4, 2004 08:48 PM
evil_elmo
Dec 4, 2001 12:10 PM
