Good Deal?
Good Deal?
I'm looking at buying a 1991 d16a6 with 85k for 600. It comes with the tranny, brand new clutch, axles, shift linkage, and motor mounts, wire harness and ecu. But no distributor. Is this worth it since right now I have a 1990 STD with bad tranny and a bad right axle.
Re: Good Deal? (esqueleto)
I think it is a pretty good deal if the motor was running good and not burning oil. Keep in mine that you will not be able to use the Si axles without changing the hubs. Your current axles will work fine though. You can use either the Si or Hf dizzy.
HTH
HTH
civichbb18c
10-22-2003 11:26 PM
Dr. Gonzo
01-24-2002 03:37 PM
