Transmission Drain and Fill plug?
I figured it's time to change my tranny oil now. Just wondering on the B16A, where are the 2 plugs located? I've never taken a look down there yet...hehe. Is it the same on teh b16 as with the d16?
Re: (sparq)
The fill plug is on the left side of the passenger side axle. The drain plug is underneath the same axle. You should be able to fit a 3/8 drive socket into the drain plug.
Re: Transmission Drain and Fill plug? (EF8_SiR)
here's the fill plug
And here's the drain
http://www.imagestation.com/pi...g.jpg
I hope that helps. Plug's are on the left side of the passengers side axels, look towards the lowest part of the tranny, your going to need a 1/4 drive and a 17 mm. Make some sort of tubing so that you can fill your tranny
Modified by Ninja_Jc7 at 3:03 PM 5/21/2003
Andrew14
21
06-28-2010 01:12 PM
