can a leaking headgasket cause......
Today I put my car in the shop for the fools to replace my headgasket which they should have done before I even got the car out from the swap, but anyways besides the point will them replacing the headgasket fix my throttle response, gasmilage, compression, overall performance? and ofcourse my oil leak will be gone.
Re: can a leaking headgasket cause...... (shadowstylz)
That depends on what parts of the head gasket are blown..
But possibly yes... an all accounts
Fixing the headgasket will definately help your compression, as for the other things, when was the last time you changed your distributor cap, rotor, plugs, and plug wires? If its been a while, you'll see a noticeable performance increase by changing those things.
Re: can a leaking headgasket cause...... (CRX PAT)
haha never been changed all that stuff is the same stuff that came with the swap. I think Im so jdm because the spark plug wires say NGK JAPAN and there blue
and u know on the left side of the motor were u can see a little bit of the head gasket? that is where Im leaking oil from.
and how much will it cost to do the cap rotor plugs and wires allt hat stuff.
JDM wires are RED as far as I know..
Blue NGK are available here in the states every where...
Re: can a leaking headgasket cause...... (Outsane)
well all I kno is my wires are blue and my motor came from japan and they have japan writen on them and my jdm comment was a joke... I need to get rid of them but I am only 16 and my swap hurt my funds for a while.
make sure to change your cam seal if its leaking on the left side of the motor~
EDIT: also the rear main oil seal behind the flywheel
guyver13
10-04-2011 03:22 PM
taimysho0
07-27-2007 09:40 PM
