b16a2 in 88 crx, car is obd1, cable tranny, code 17 = vss, need help!
guys i dont have vss on my car, is a 88 crx, car is obd1, im running a b16a2 with a 95 gsr ecu, im getting code 17 which is vss. How do I fix this? What do I need?
different cluster? vss cable?
need a list of stuff
thanks again.
thanks again.
Re: b16a2 in 88 crx, car is obd1, cable tranny, code 17 = vss, need help! (iNetForce)
did you change your car to obd1 or did you just buy an obdo to obd1 piggy back harness?
is the the tranny your using cable or hydraulic. if its cable you will need to change the mechanical vss to electric and then wire in the 3 wires(+,-,vss signal to ecu)
Re: b16a2 in 88 crx, car is obd1, cable tranny, code 17 = vss, need help! (Cm91h22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cm91h22a »</TD></TR><TR><TD CLASS="quote">did you change your car to obd1 or did you just buy an obdo to obd1 piggy back harness?
is the the tranny your using cable or hydraulic. if its cable you will need to change the mechanical vss to electric and then wire in the 3 wires(+,-,vss signal to ecu)</TD></TR></TABLE>
I changed to obd1, I used both harness, obd0 and obd1, car is completely obd1, not only the harness at the ecu.
you need to wire up an electronic vss to your ecu. grab one from an obd1 civic. the ecu looks for a vss. vtec will not engage without it. i'm an eg guy but ive done several ef swaps but ive heard you can rig the cable in a electronic one so you dont have to get a different cluster. but im not too sure. but yea you need to wire up an electronic vss to your ecu.
Re: b16a2 in 88 crx, car is obd1, cable tranny, code 17 = vss, need help! (RedDelSol si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedDelSol si »</TD></TR><TR><TD CLASS="quote">you need to wire up an electronic vss to your ecu. grab one from an obd1 civic. the ecu looks for a vss. vtec will not engage without it. i'm an eg guy but ive done several ef swaps but ive heard you can rig the cable in a electronic one so you dont have to get a different cluster. but im not too sure. but yea you need to wire up an electronic vss to your ecu. </TD></TR></TABLE>
can u get deeper on this part of wiring the vss to the ecu?
timdareez
10
09-10-2009 05:39 PM
iNetForce
06-02-2004 06:25 PM
firstgenrex
02-17-2004 03:11 PM
