code 9 and code ?
Old Jul 6, 2004 | 05:31 AM
jdmrex91's Avatar
Default code 9 and code ?
picked up a 91 gs teg for 150$ motor looks good, anyways I got it running for the first time over the weekend and got 2 codes
1. code 9, that means I need a new dist due to a bad sensor?
2. I'm not sure on this code four slow flashes then three fast flashes, is that code 43???
I really am new to the engine swap and working on my own cars so any help from any experinced h-techers would be greatly appreciated!!!
Old Jul 6, 2004 | 05:47 AM
crx_88_si's Avatar
isnt 43 fuel supply system? you sure it's a 91? check the ecu.
jdmrex91's Avatar
Default Re: code 9 and code ? (jdmrex91)
anyone?
Old Jul 6, 2004 | 05:49 AM
jdmrex91's Avatar
Default Re: (crx_88_si)
yes it is a 91 I checked and rechecked yesterday before I posted, so it is a code 43? (4 slow 3 fast)
Old Jul 6, 2004 | 06:15 AM
jdmrex91's Avatar
if it is fuel supply system what would i do to fix that?
Old Jul 6, 2004 | 07:23 AM
Filthy Focker!'s Avatar
Default Re: (jdmrex91)
Most probably the throttle postition sensor. It sits on your throttle body and signals the ecu when your throttle moves. Grab a voltmeter, turn your ignition to on, and check to see if power is reaching the sensor.
if so, next, have a buddy press on the gas (to move the pedal), tap into the signal wire from the tps and see if voltage goes up as the throttle opens (pedal depresses further). I don't recall the exact specs, but voltage should go up...
fs
Old Jul 6, 2004 | 07:30 AM
jdmrex91's Avatar
Default Re: (filthy_shovel)
awesome i'll try that as soon as i get home from work!
Old Jul 6, 2004 | 09:38 AM
jdmrex91's Avatar
if the tps sensor is bad can i just swap it out for another one?
Old Jul 6, 2004 | 09:45 AM
crx_88_si's Avatar
yes
dot.org
Mar 18, 2007 06:45 PM
ALLshowNOgoLS
May 4, 2006 02:19 PM
v4racing
Dec 5, 2005 04:44 AM
Me2
Apr 11, 2004 03:13 PM
4gnhatch
Jun 2, 2003 12:35 PM
