SUPERMODEL w/ My Car + Tranny Mount Removal Questions + Pics
Re: SUPERMODEL w/ My Car + Tranny Mount Removal Questions + Pics (Traction)
Word of advice, buy a helms manual. until then use this http://www.binghamtonlife.com/manual/manual.htm
and more particular this page http://www.binghamtonlife.com/...n.htm
Keyboard Humorist
The side mount -
Remove the 3 bolts that attach the mount to the tranny plate.
You can then roate the mount up towards the sky and flip it out of the way.
Rear mount - remove those 3 bolts that you see in the picture below.
Front mount - if you have have exhaust off the car (Helms says you are supposed to remove teh lower pipe) then remove the bolt that goes sideways (runs from driver side of car to passanger side).
Then remove the 2 bolts that hold the mount to the tranny. It is a LOT easier to get to these bolts if you remove the radiator. You should already have the hoses disconnected so it's really not much work to pull the radiator out.
You speedo cable looks fawked. It looks like you broke the rubber off the sleeve of the cable. It could just be the pic though.
At this point I would suggest you remove the speedo cable drive gear completely from the tranny. You should be able to see a small bolt (10mm or 12mm socket) holding down a small triangular shaped plate right next to the speedo cable drive gear where it enters the tranny. REmove that bolt and the little triangular plate completely. Pull the entire gear assembly out of the tranny.
TIP - Before you put the tranny back into the car put the gear drive back in FIRST. That triangular plate slips into a slot on the gear housing and it's sort of a pain to get it just right when the tranny is already in the car.
Location: I told you to wait in the truck in Texas, United States
So where is the supermodel?
Inside the black boot,there is a horseshoe shaped clip which slides into a groove,
You can usually squeeze and turn it and it will come out.
Or just pull up the boot then it will be self-explainitory..
http://www.binghamtonlife.com/...7.jpg
Re: (DOHCZCCRXSi)
Im having a load of fun doing it myself, learning alot, tore apart alot of front suspension trying to pry out the axles just so I didnt have to try a pickle fork and dmage the boot.
I ended up going after 30 min of hammering without a budge
The end axle nuts are what killed me time wise, took me 20 min to find a hollow long bar, put it on, all my weight on it and the ****** bent, so I went to my work and stolen a 9 foot massively thick piece ($650 worth) piece of aluminum, cracked it off
Cut 2 feet off to use as a breaker bar for the motor bolts and brought the rest back lol
And the kid is my little sister
Re: (Traction)
I was gonna install my new clutch and flywheel this weekend. Good thing i chickened out. Turns out my clutch was toasted, origional flywheel scored, and my left halfshaft gernaded. The halfshaft literally fell apart when it came out of the car.
Took it to a shop around here, and they are doing all of it. They also busted my radiator (plastic top origional) so i get a new one
ps. way to be a good role model for your younger sister. she's what, 11? and you told her to flick off the camera? real nice, buddy
Re: (Fred.Rodgers)
**** I didnt see that speedo post,
As you can see I pulled off the boot and it slides freely no problem, but I couldnt feel a clip, and after the boot was pulled up, the ****** was still stuck dead in there so I just ******* yanked on it and the cable seemed to pull out 6 inches then caught and I am unable to push it back in
Dunno what to do
Also the shift rods might be of some trouble for me
BTW- My sister is 7, eeryone says shes huge for her age, she saw me giving it the finger and jumped off the engine and did the same lol
Shes gonna be into cars, gotta learn the gestures
Dunno what to do
As far as the bitch pin its not thast bad, I use a punch to get it out but I have also used flatheads, its not that bad.
The cable all you should do is grab the rubber boot and pull it out of the tranny and the part that comes out should be a few inches long.
Re: (kid-honda)
I didnt see nor feel one where abouts on the unit is it, I dont see how that clip would hold it in so dam *** tight as it was
How is the clip removed? I could only really get could access to this after I removed the drivers side axle and was under it so I couldnt see anything, just by feeling
Dont search because no else ever had any of these proplems about once a week...no really.
https://honda-tech.com/zero...age=1
Keyboard Humorist
Re: SUPERMODEL w/ My Car + Tranny Mount Removal Questions + Pics (SEA Hag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEA Hag »</TD></TR><TR><TD CLASS="quote">Dont search because no else ever had any of these proplems about once a week...no really.
https://honda-tech.com/zero...age=1</TD></TR></TABLE>
HAha! That's link to his old post!
Keyboard Humorist
Re: (Traction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Traction »</TD></TR><TR><TD CLASS="quote">I didnt see nor feel one where abouts on the unit is it, I dont see how that clip would hold it in so dam *** tight as it was
How is the clip removed? I could only really get could access to this after I removed the drivers side axle and was under it so I couldnt see anything, just by feeling</TD></TR></TABLE>
Remove the gear assembly from the housing and you can inspect it however you want.
Re: (4drEF)
lol ahaha , ya that was last weeknds attempt at the same thing, just kept driving to a minimum until I could get my hands on some free time, breaker bar and a pickle fork
4drEF, I just went outside in my ******* boxers, 1am, I took off that little place held on by a 12mm bolt, I took the plate off and there is another hole underneath the plate, I still couldnt pull anything around, didnt look for the clip because its do dark and I was just going by the porch light 40feet away, we really need a garage light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEA Hag »</TD></TR><TR><TD CLASS="quote">Dont search because no else ever had any of these proplems about once a week...no really.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">HAha! That's link to his old post!</TD></TR></TABLE>
Lol, nice one, sea hag.
Location: Land of the free, whoever told you that is your enemy
Re: SUPERMODEL w/ My Car + Tranny Mount Removal Questions + Pics (yellowcrx1991)
really though man it isn't that hard, just remove bolts and it will come out. there is nothing in engine or tranny removal from our cars that can't be figured out by simple common sense.
Re: SUPERMODEL w/ My Car + Tranny Mount Removal Questions + Pics (4drEF)
funny isn't it...glad to see all these useful threads being made.
My favorite is when someone takes a picture of a clearly visible bolt and asks how to take it out. Am I missing something here?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEA Hag »</TD></TR><TR><TD CLASS="quote">funny isn't it...glad to see all these useful threads being made.
My favorite is when someone takes a picture of a clearly visible bolt and asks how to take it out. Am I missing something here?</TD></TR></TABLE>
yeah I was just on ef-honda and he made the same exact post on there. The axles that are so ridiculously hard to remove, I did yesterday when I changed to EX brakes, wasn't TOO hard. Common sense people, but Im not hating your a noob, just wish you would have taken my advise in your last thread and bought a haynes.
Re: SUPERMODEL w/ My Car + Tranny Mount Removal Questions + Pics (CRXBart)
Are you talking about me wanting to know how to remove the bolts?
What I meant was if I remove the tranny from the mounts, or remove the mounts from the chassis and drop them along with the tranny
I ended up almost finishing today, Im about 10hours total working over the 2 days I tried this
One thing I left though was the starter, say your looking at it from the front of the car, theres 2 studs, the closest one to you is lowerr and the one furthest away is about an inch higher and an ich further away, which one of these studs is the main power wire bolted onto?
Thats the last questions I promise lol
chrisff521
05-19-2010 06:06 AM
a1320addict
03-13-2006 08:43 PM
SurferX
03-03-2003 02:16 PM
