b16 in a 4g civic?
b16 in a 4g civic?
What parts do would be needed to swap a b16a into a 4th gen civic? I know I need: Motor, Tranny, Mounts, Shift Linkage, Axles, and ECU. What else is there? Also, what ECU do I need? Is it the PR3, OBD 1, or OBD 2? Thanks a lot.
Re: b16 in a 4g civic? (mmskater15)
PR3 is obd0 and obd1. If you do not want to convert to obd1, then you will want to use the obd0 ecu. It is a lot more simple to go that route.
Re: (sloweredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweredcivic »</TD></TR><TR><TD CLASS="quote">try the search button in the upper right corner of your screen</TD></TR></TABLE>
