Looking to go with a budget Bolt-on + Nitrous setup - B16A/Crx
I'm going to have some faith in HT
As my car sits right now. 90 Crx, Hasport Mounts, Y1-LSD, obd-0 pw0, stock intake system and stock header/exhaust. The swap and nothing else.
I'm looking for the following.
Budget Header to fit the crx/b16 combo - was looking at the Hasport Header
Intake - I have a used one here I may change out the filter on and use
Exhaust - I hate the raspy high pitched "fart buckets", I'm looking for a toned down quite/bold sound and get a exhaust shop to custom run it
And Finally...
A Nitrous Kit - Dry Shot into the Intake Piping, maybe a 75 shot?
- I don't mind spending money on all the bells and wissles to make this safe, bottle warmer if neccessary, all the gauges.
- Will I be needing to upgrade my fuel set-up?
- Not sure how I'm going to mount the bottle yet, I have a gutted rear.
- Is upgrading to another ECU or Hondata a must, or a "would be good"
When all is said and done, I'd like to break into the 12's with slicks.
Thankyou for your feedback.
Kevin.
Modified by kevinoneill at 6:31 PM 11/18/2006
And Finally...
Kevin.
Re: Looking to go with a budget Bolt-on + Nitrous setup - B16A/Crx (kevinoneill)
dont run a dry shot unless you have some kind of engine mgmt such as neptune or hondata to add extra fuel. Im running neptune and love it. definetly upgrade to a bigger fuel pump either way you go. With a b18c and a 50 shot i ran a 12.9 so you goal is probably attainable.
http://www.tuninglinx.com/html....html
https://honda-tech.com/zerothread?id=1171730
http://www.dynotunenitrous.com...t.asp
those are some good links to get you started.
Re: Looking to go with a budget Bolt-on + Nitrous setup - B16A/Crx (chadmasterc)
Thanks for the links. I've refined my list some. Anything needed not listed? or listed and not needed?
Header
DC Sports Header
Hasport Header
Exhaust
Keep old exhaust in place, mount new mid way threw car
2 O2 Sensors , how to deal with, have 2 tapped
Intake
Use old Intake laying around
Nitrous Kit
$530 75 shot dry zex kit
WOT micro switch, NOS makes a good one, it’s like 12 bucks from summit.
Bottle heater
http://www.dynotunenitrous.com...ct=17
Fuel pressure
Nitrous pressure gauges
http://www.dynotunenitrous.com...t=132
A/F Gauge
http://www.dynotunenitrous.com...t=129
Remote Bottle Opener
http://www.speedshop.org/store...ct=16
window switch. MSD make a great version - only allows in set rpm range - 4K RPM and terminate at 7800
Tires
m&h 24.5x8.5x13 slicks on bogarts ?
Fuel
NGK BKR-7E $2 each. replace often, after every bottle?
ECU
pw0 current... pr3?
$450 Digital SCI+ Ignition, PN 6350
http://www.msdignition.com/sci_1.htm
Notes:
Don’t spray in 5th gear, don’t spray for more then 15 seconds at a time.
Header
DC Sports Header
Hasport Header
Exhaust
Intake
Nitrous Kit
Bottle heater
Fuel pressure
A/F Gauge
Tires
Fuel
ECU
pw0 current... pr3?
Notes:
you need to convert that zex kit to a wet kit, basically all you need is another solenoid and the nozzle/fuel line. if you dont add extra fuel your engine will go boom. I know the zex kit is supposed to increase fuel pressure but i wouldnt do that with a 75 shot. Just go with this kit http://www.dynotunenitrous.com...t=100
its cheaper than the zex kit and comes with everything you need. If you already bought the zex kit im pretty sure they offer the wet conversion which comes with everything you need to convert it to a wet kit.
I WANT 2 GO BIG ON NITROUS!!!!!!!!!! i want to know what do i change or do to Use as much NITROUS as i can On Race Gas on the Track on my All motor Setup!!!!!!!!
B20b block Stock Sleeves Block Guard 84.5mm Arias 11:8:1 Piston
Rods are Pinned (stock)
Type R water/Oil Pump
Ctr Pully
Custom Head Gasket for High Compression
B16 Head Ported/Polish Full Omni Valvetrain
Milled HEAD 440Injectors
Jun 3's or Have Custom DH RACING CAMS
Rage Header 2.0 Big Tube
Want to Know what Spark Plugs to run? Wat to Change !!!!
Wats biggest i can go On Squeez?
What System To BUY???????????
Re: (Cali4niaEk9)
dude, im gonna say it again. just search and make ur own damn thread. holy fawk, u pasted exact same thing in 2 other peoples threads. sheesh!! then made ur own thread with exact same words. just use one thread man
but, best bang for ur buck, make a holder to hold 6 cans of ether with lines running to ur airfilter. make a button to push nozzles on all 6 cans and u can smoke a viper on squeez!!!
SiR Inspired ED7
11-02-2008 05:51 PM
saccord
09-25-2005 01:23 PM
