tranny locked up?
Old 02-12-2007, 05:46 PM
xlusiveracer's Avatar
Default tranny locked up?
well i did a tranny flush yesterday and i found out there was a leak when i would put tranny fluid.and now today when i try to drive it wont work.i would put it in gear but i aint going anywhere. it would just rev. is my tranny expletive up? is there anyway i could fix this or do i need to buy a new tranny?
Old 02-12-2007, 05:53 PM
sirtef9's Avatar
Default Re: tranny locked up? (xlusiveracer)
Sounds like your diff pooped on ya, all gears no movement? you can find a tranny for under 500$ and a diff would be around 350 but with labor
Old 02-12-2007, 07:21 PM
Default Re: tranny locked up? (sirtef9)
well when i put it in reverse i could move just a little but then it stops.so it might be my diff. is that what happens when thers low tranny fluid.because the leak i have (where ever that is) is pretty big leak and i drove it around.
Old 02-12-2007, 07:52 PM
white90crxhf's Avatar
a big leak and you drove it around? i bet all of your bearings are bad now.
Old 02-12-2007, 07:58 PM
Default Re: (white90crxhf)
well i dont know if its a big leak but you could tell its leaking.what should i do?
Old 02-12-2007, 09:05 PM
Default Re: (xlusiveracer)
also to add my car dont move at all.it doesnt roll newhere.if i try to push it it still wont move.the front tires are locked but not he back tires.so what do you think it could be? would fixing that leak and fillin up the tranny would fix it?
Old 02-13-2007, 04:11 PM
or could it be my axles?
Old 02-13-2007, 07:09 PM
bump anyone? please i need help.
Old 02-13-2007, 07:19 PM
i think you broke something on the inside if you can't push it in neutral.
Old 02-13-2007, 08:11 PM
mahatma's Avatar
j00 fucked it up. i wouldn't even waste the fluid it would take to attempt driving it again.
Old 02-13-2007, 08:14 PM
Jonknee's Avatar
***** fucked!!! take it out and post some pictures of the carnage
Old 02-13-2007, 09:52 PM
Default Re: (Jonknee)
so its my tranny for sure then?
Old 02-13-2007, 11:56 PM
allsho's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xlusiveracer &raquo;</TD></TR><TR><TD CLASS="quote">so its my tranny for sure then?</TD></TR></TABLE>
lol ya people over the internet know the problem FOR SURE.
Take the car to a mechanic.. ugh cheap *** people. Do **** properly.
Old 02-14-2007, 12:28 AM
Default Re: (allsho)
well sorry from the comments they said it seemed like they were referring my tranny is messedup.
Old 02-14-2007, 06:51 AM
Gearspeed-Performance's Avatar
We can only speculate and guess...take it to a good mechanic and have them check it out
Old 02-14-2007, 11:10 AM
Default Re: (GearSpeedEF7)
alrite thanks guys.
creepass
07-04-2009 05:13 PM
WOODman
05-26-2005 03:09 PM
Quick Reply: tranny locked up?
