which ecu for sohc vtec?
ok i need some advise on this, i recently swapped a jdm d15b into my si. now i need the right ecu for this motor. should i get a obd0-obd1 jumper and use a obd1 ecu or can i use a obd0 b16 ecu?
Re: which ecu for sohc vtec? (1sikhatch)
I am subscribing...I would think the cheaper option would be a JDM P27 ECU right? The SOHC VTEC...I think they are OBD0, but you wouldn't go wrong with a P28 OBD1 ECU, but might cost more to change overe to OBD1.
I wanna know this also,
If you are tuning, is it better on an OBD0 or an OBD1 ECU. Any differences...
I would think P28 (which of course is obd1). The Jdm d15b is a "three stage" vtec (for fuel economy), so the p28 isn't the exact ecu for the motor, but I would assume it would work. Maybe not...
Re: which ecu for sohc vtec? (makoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by makoto »</TD></TR><TR><TD CLASS="quote">I would think P28 (which of course is obd1). The Jdm d15b is a "three stage" vtec (for fuel economy), so the p28 isn't the exact ecu for the motor, but I would assume it would work. Maybe not...</TD></TR></TABLE>
not all d15b's are stage 3 vtec if it has 2 vtec silanoids however you spell that then yes it is???
OBD0 ecus don't have vtec other then the PR3 and PW0 (B16A ecus).
You want a P28, OBD1. I started making swap harnesses for them. PM me if you want to buy one. They are cheaper then Rywire.
Pirate General...YARRRR
Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">OBD0 ecus don't have vtec other then the PR3 and PW0 (B16A ecus).
You want a P28, OBD1. I started making swap harnesses for them. PM me if you want to buy one. They are cheaper then Rywire.</TD></TR></TABLE> Other then you being a canuk I'd trust you
I'm sure you do great work
Always good to see more people doing stuff for these old cars
Your info is correct you do want a p28 or you can run a p08.
Re: which ecu for sohc vtec? (GreenBean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenBean »</TD></TR><TR><TD CLASS="quote"> I wanna know this also,
If you are tuning, is it better on an OBD0 or an OBD1 ECU. Any differences... </TD></TR></TABLE>
Any takers...
Any takers...
Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote"> They are cheaper then Rywire.</TD></TR></TABLE>
peace of mind is worth the little extra cost.
Any takers... </TD></TR></TABLE>
obd-1 computer's use a more powerful processor. resulting in a better, more thorough tune.
TurbodTegra
03-10-2011 12:46 PM
