Wheel bearing
Wheel bearing
I have integra rear disk on my 90 civic and the wheel bearing is bad. The part store will only sell me a whole hub assembly.
Doe sanyone have a bearing number so I can go to miller bearing and get a new bearing. I would take it apart and go get one but I work from 7-6 so when I get home they are closed and this is my only vehichle so it cant be down for to long
Re: Wheel bearing (ef-hatchcrap)
I know you may be on a budget bro, when I do bearings, I do the hub too, its just my style. I have had to grind the old race of of the old hub, the labor just isnt worth it, is the price much more, cause the time will be fast to just change out the whole thing.
Now here is the funny part, is this new hub going to come with the new bearing already installed or will the bearing be sitting in the same box as the hub, I hate it when they force you to buy an assy and it is not even assembled, like a door window regulator plus the motor and they come in two completely seperate boxes, ******** could not even box them up in a set.
Understand bro, what I should have said was, is the bearing in the box with the hub so you can get the part number from the bearing box and then go order it elsewhere or is it preassembled?
Is there some links in the EF FAQs to some parts places here on the web so you can look it up, someone will be along soon to give you some more help though, good luck.
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-hatchcrap »</TD></TR><TR><TD CLASS="quote">Yes they do come seprate that is why I was just going to replace the bearing</TD></TR></TABLE>
No, actually they don't. Every Honda rear wheel bearing I have sitting on my shelf here includes the hub.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan »</TD></TR><TR><TD CLASS="quote">Understand bro, what I should have said was, is the bearing in the box with the hub so you can get the part number from the bearing box and then go order it elsewhere or is it preassembled?</TD></TR></TABLE>
The bearings come already pressed into the hub.
Bnjmn
09-20-2005 03:43 PM
