hydro conversion help hasport or innovative
oke im stuck picking between setups i want to convert my 91 civic dx auto to 5speed but im stuck picking between hydro or cable i got all parts for cable and the tranny but it need to get re threaded because the rear tranny bolts striped when i did a lunch with my buddys y7 y8 mini me camed pulled the bolts out of the rear tranny mount so im desidesing on geting the tranny fixed and used in my auto conversion or geting a 96 ex or 92 eg tranny for my 91 dx whitch are both hydro or should i fix my 91 si tranny and go cable
i can get the hasport (EFDHC) Hyrdo Transmission Conversion Kit for 88-91 Civic/CRX with D-Series Engine, for $249 usd
or the Innovative Mounts B/D/H/K Cable/Hydro Conversion, for $240 usd this kit is regulatly 249 also i can get the innovative one for 240 shiped to canada
what u guys think i should do
Re: hydro conversion help hasport or innovative (mario_pic)
just need to know tell me whats better
Innovative hydrolic kit
or
hasport cable adapter to hydrolic kit
or
help me out guys i need info i only got the deal with the innovative kit should i get thiss one http://cgi.ebay.ca/Innovative-...wItem or thiss one http://cgi.ebay.ca/ws/eBayISAP...h=022 by hasport
Modified by mario_pic at 9:27 PM 1/2/2008
Re: (welfarepc)
i have helli coiled it once already and i know if i do it agan with my race mounts and im planing turbo after words i will deffently rip them out agan im not willing to remove my tranny after i do the swap and install it lol less work the better
FWIW the innovative part you reference above is for the hydro actuator only, if you go that route you will still need a mount/adaptor and rear bracket to use the D-series hydro trans in your car. The advantage of using the 96-00 Civic D-series hydro trans is that it is easier to find a good used one and they have steel shift forks which are much stronger than the aluminum shift forks in the 88-92 D-series transmissions. Good Luck.
Re: hydro conversion help hasport or innovative (keithg)
wi got a y7 wish bone tranny bracket that good for my ef ? and also what other motor mounts do i need or can i use most stock mounts i need a nice list so i know what to get when i go to the scrap yeard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mario_pic »</TD></TR><TR><TD CLASS="quote">wi got a y7 wish bone tranny bracket that good for my ef ? and also what other motor mounts do i need or can i use most stock mounts i need a nice list so i know what to get when i go to the scrap yeard</TD></TR></TABLE>
With the Hasport EFDHCRH kit that includes the rear wish bone tranny bracket and billet right mount adaptor plate you could use the stock EF mounts or the Hasport billet stock replacement mounts and the stock axles. You could use either the hasport mechanical clutch actuator or the innovative hydraulic clutch actuator.
Re: hydro conversion help hasport or innovative (crx_R)
Innovative is a much better kit.. trust us from experenice.. We sell both kits and innovative has less problems... if you need a set let us know..
1000hp on non soild bushing mounts
Re: hydro conversion help hasport or innovative (Camp1320motorsports)
id like to get a set of them after i do my motor swap but for know i just want to get my 5 speed hydro tranny in all i need to know now is what tranny mount to use on the passenger side fender wall will a stock 91 civic mount work or will i need to get a 92-95 mount to get it to fit
hey, i see that you sell innovative and hasport. i have a 92 da integra. i did a b16a2 swap in it with the cable trans. i have a gsr trans sitting in my garage that i want to swap in. i was doing some research and saw that hasport makes a conversion kit for my car w/ that particular swap. all it has is a trans mount and some levers. do i need to purchase anything else for it? is hasport the way to go for what im trying to accomplish? please advise.
Jonnyr4c
02-23-2005 10:03 AM
actuator, buy, cable, camping, conversion, conversions, crx, efdhc, hasport, honda, hydro, hydrolic, instructions, kit, odyssey
