need help with my overheating b16 swapped 88 si civic!!
im jus wonderin, would a bad thermostat cause the check engine light 2 come on??.. i bought my si a couple months ago n it ran fine. then all of a sudden it started heatin up on me like krazy n now its drivin me krazy! I hate to c it sittin there but cant help it cuz $ is tight right now... im kind of leanin towards that the head gasketmight b out? i keep filling up the radiator with anitfreeze but wen i go bak to check it, it seems to b empty so im left clueless. the water pump is not leaking at all n theres no signs of there being a hole in my hoses n the radiator is in great shape.. but jus wonderin if any1 has had to deal with something similiar 2 this.. so id appreciate the help!
Re: need help with my overheating b16 swapped 88 si civic!!
has the system been bled?? have you changed the thermostat? does the heater blow hot air when you turn the heat on? have you pulled the cel code? do your fans turn on?after all that a leak down test would confirm blown head gasket...
im actually jus gettin to workin on it because bills were hella tight for a min but i have the $ to spent now. but im thinkin its the head gasket cuz the check engine light is on.. could a messed up thermo cause it 2 come on??. but wats actually funny to me is tht it will start to cool down wen i have it at a complete stop but wen i get on the gas it will rise quickly.. by the way how much wld a leak down test cost??
DO IT ON ALL FOURS
Buy the tester off eBay for around $40 and do it yourself. It will be cheaper than taking it to a shop, plus you will have to tool for future problems.
depends on what your local mechanic wants to rape you on the bill...you can google it and buy the tester and diy. do the cheap fix first, pull the cel code, change the thermo, flush the system/bleed it, also do the heater trick check to see if you got hot air blowing out your heater when the car is heating up, if its luke warm it could be air in the system or a waterpump going bad.
ight sounds great!.. i can check off the water pump bein bad cuz its not leakin at all. how wld i get da cel code neway?? im new to dis so dnt trip lol
check the faq's put the key to the on position and look at the ecu there should be a blinking light, long flashes stand for ten short flashes for one.
edit: oh obd0 or obd1
would i b able to go down 2autozone n have them check da cel?? i kno they do tht ish 4 free.. im not sure wat obd i have cuz i didnt kno who the previous owner of my si was so im stuck guessin
DO IT ON ALL FOURS
Is your car OBD-0 or OBD-1?
If it is OBD-0 then pull the carpet and plate (if its there LoL) and just watch the L.E.D. blink short flashes are 1s and long flashes are 10s. (You have to have the key in the 2 position or you can just start the car.)
This may help a little... if the L.E.D. goes (-----) (-----) (--) Then it is code 21.
There can be more than one code, and after it has flashed them all then it will repeat itself.
whats the code though. it could not even have anything to do with your overheating problem. only thing i nkow would have anything to do w/ temp. is a code 6 which is collant temp sensor. and a pressure test at my work is like 60 bucks, but i dont know about other places. are you getting any leaks from anywhere?
edit : damn that was lot of posts in the time it took me to type mine ha.
DO IT ON ALL FOURS
AutoZone can't help you, nor can any other parts stores. There is no machine for PRE-OBD-2 Hondas.
GroundZer0 are you talking about a Leak down Test or a Compression Test?
like i said im not sure who the previous owner was so im not sure if its obd 0 or 2. wld it possibly be labeled on the ecu cover or??.. n arit ill do tht as soon as i get home. im visiting wit my moms but ima check tht out as soon as i get bak.. is there a code for a blown gasket? or am i assed out wit tht part??
DO IT ON ALL FOURS
Try and type better, it is hard to understand what the hell you are talking about sometimes. It makes me actually have to read what you type LoL...
When you look at the ECU you will know. If it has a little window with a L.E.D. in it then it for sure is OBD-0. I HIGHLY, HIGHLY doubt that it is a OBD-2. If it don't have the L.E.D. then it is probably a OBD-1 ECU.
There is no code for a blown headgasket, not even on 2010 cars LoL.
The ECUs are labled on the side with a TAG. It will be white if it hasn't been torn off, pull the numbers off it and tell us what it is. If it has a L.E.D. it will have PR3 or PW0 on that tag somewhere. Pull the codes if you can that is the most important part.
haha sorry yo!.. im using the internet on my palm phone n i dnt feel like pushing the dam buttons 3 times to get down wat im tryna say so dnt trip :p lol. but arite im gonna check all this out n let u know but thanks every1 for the tip's and pointer's!! muchos mas!! lol.
Devilz Asylum
18
07-03-2015 04:39 PM
dtddemon
12
03-25-2009 05:16 AM
