A/C & PS Compatible Turbo Setup
Old Mar 19, 2010 | 09:52 AM
Basilias's Avatar
Default A/C & PS Compatible Turbo Setup
I've searched honda-tech and I have found info but none of it is concrete. Basically as far as I've been able to tell basically the make it A/c & PS compatible is I need a compatible downpipe and manifold, is this correct?
If so what company makes a great downpipe and turbo manifold for this?
Are there A/c compatible ramhorn manifolds as well?
One more question I have is do I still need to get the halfcore radiator or should I be fine if I stay with my stock one?
Thanks if you can help me. Just looking for some concrete facts.
Old Mar 19, 2010 | 02:54 PM
madblkscientist's Avatar
Default Re: A/C & PS Compatible Turbo Setup
i hope someone will help you bcuz i asked the same question b4, i got 1 or 2 ppl that gave me positive feed back but eventually i had to do all the reseach which could have been avoided
off the back of my brain peakboost, but there are others i forgot the company names
but look at
peakboost*
in-line pro
spoolin
go-autowerks!*
there are more but cant remember hope that helps
Old Mar 20, 2010 | 07:51 AM
Si GUY99's Avatar
I don't know about a teg , but on a ek the ac is too close for comfort to me
Old Mar 20, 2010 | 08:26 AM
reboosted's Avatar
you do need a downpipe and manifold that are made for p.s and a.c.also might want to change the fans from pullers to pushers. their are alot of great companys that make these products just spend some more time looking what will fit your budget
Old Mar 20, 2010 | 04:48 PM
which company's? do you know of
Old Mar 20, 2010 | 04:57 PM
TheShodan's Avatar
Moderator
Those stated above including AFI (Arizona forced inductions)
Old Mar 21, 2010 | 08:48 AM
reboosted's Avatar
their are four are five companys, afi is one of them. i still have ps and ac in my civic and made good power.
Old Mar 21, 2010 | 10:20 AM
SDHonda153's Avatar
Yes, they make them. I went with the Full-Race A/C compatible manifold. They sell a down pipe to go with it, but I ended up making my own because the one they sell hangs to low for me. Installing is always fun Everything is soo close together. As everyone else was saying, you're going to have to get pusher fans and flip them over to the front side of the radiator and condenser. Also the power steering bracket has to be cut down to fit with the manifold. I would really recommend wrapping the manifold and A/C lines with a fiberglass wrap. Before I wrapped mine the A/C was barely colder than the outside air, and I also burnt through one low pressure line and leaked A/C oil all over the motor. Even with everything still in the car it made just about 400 to the ground.
Here is a picture of what mine looks like with everything.
The other picture is my first turbo/AC/PS setup which was a log type manifold which didn't require cutting the PS bracket and also gave more room between the manifold and A/C lines.
First Setup (Years Ago)
Hopefully this helps a little and clears a little bit up.
Old Mar 21, 2010 | 02:28 PM
reboosted's Avatar
i made 513whp and 335tq on pump gas. since then ive changed the turbo and the intercooler. i also got a set of pro1 camsthat im thinking of putting in.
Old Mar 21, 2010 | 07:57 PM
ScorpionT's Avatar
The AFI and Full Race setups are very nice, cant go wrong with either. Minor trimming is usually involved with PS/AC manifolds, but its no big deal. And as mentioned, changing the fans is a good idea.
Old Mar 25, 2010 | 12:07 PM
reboosted's Avatar
Here are some pics before and after my IC upgrade.
Old Mar 26, 2010 | 10:29 AM
Redcoupe's Avatar
What turbos are ya'll running? Any V-Band housings?
Old Mar 26, 2010 | 05:31 PM
SDHonda153's Avatar
GT3076R - 4 bolt downpipe
Old Mar 26, 2010 | 06:16 PM
reboosted's Avatar
t3/67 h.o bb
Old May 1, 2010 | 02:23 PM
8OOSTED's Avatar
The cheapest A/C friendly manifold I found so far is the one made by Spoolin Performance, it's about $650 though. Anyone know of anything cheaper?
Old May 1, 2010 | 02:41 PM
azandford's Avatar
you could always go with an ebay cast mani... not the best for flow but most are ac/ps compatible
Old May 1, 2010 | 10:01 PM
Zer0_SpeedWorks's Avatar
topmount t67 ac and ps
Old Dec 21, 2011 | 03:35 AM
borislunov's Avatar
What is the manifold?
Old Dec 21, 2011 | 03:52 PM
sleepencivic's Avatar
I need to take a picture of mine...all these guys say its tight but mines real tight! P-fab ram, ac/ps working, full size radiator (JDM front integra) 3 inch down pipe with a gt3540s, its a bitch to work on and get your hand on bolts.....good times!
Old Dec 21, 2011 | 08:39 PM
lilcoolguy90's Avatar
b16 or gsr? whats the specs on ur motor? planning on using that turbo also.
Old Apr 3, 2012 | 07:27 PM
NOSPNSRS's Avatar
I used the log type bseries manifold, so I didn't have to cut any brackets, and bought the ebay drivers side exit 3" 5bolt downpipe (which I had to cut shorter and made fit next to the a/c) but it fits. Only thing is the downpipe hangs too low for my taste so I just raised the car, NYC streets are bad enough as it is so I'm doing myself a favor not being that low.
Old Apr 3, 2012 | 08:54 PM
Malakai's Avatar
From the pics looks like you would have to change to half size rad. With the exception of the couple able to run full size.
Old Apr 4, 2012 | 01:40 AM
ek_si808's Avatar
I have a GO-AUTOWORKS street x kit in my coupe. Really great kit. Will post pics later but only problem had was major bending of the ac lines. Will post back once I get dyno numbers!
Old Apr 20, 2012 | 12:41 AM
careawholelot's Avatar
anyone else using top mount with a/c
Old Apr 20, 2012 | 01:13 AM
slowtegkauai's Avatar
I emailed go-autoworks and Greg said he can make me a Ramhorn to be A/C and P/S compatable for $650 more than there cast log mani. So im gussing around $800? I'll let you know when I get a straight answer.
