Erratic RPM at 3000
Old Mar 16, 2010 | 07:53 PM
integrainside's Avatar
Default Erratic RPM at 3000
I origionally had a problem with a Blox throttle body sticking. Could never get it resolved so i bought a new BDL throttle body. After i put it on the sticking went away but i have a new problem. The idle is higher, 1200 rpm, was 1000 rpm prior. and when i hold the gas at 3000 rpm it stays for a sec then drops to 800 then back to 3000 then down to 800, and so on. But if i hold it at 4000 it stays just fine. checked for vacume leaks all around. tried new gaskets, nothing helped, so i tried using hondbond with no gasket and same result. Did voltage checks on IACV and it checked out fine. Any advice?
PS- this is a B18C fully built Turbo race car, no a/c power steering ect.
Old Mar 16, 2010 | 08:45 PM
HiProfile's Avatar
Default Re: Erratic RPM at 3000
Sounds like a TPS problem. Hopefully you have an EMS that will let you calibrate it, otherwise it might require some rigging.
Higher idle is because it needs to have the idle reset & properly adjusted. Unplug IACV, set idle to ~400rpm, unplug/reset ecu, reconnect IACV and ecu.
Old Mar 16, 2010 | 09:14 PM
I already replaced the TPS with an Omni. Calibrated it and it is good. Sorry forgot to mention that.
cjwang2
Feb 9, 2015 10:04 AM
integrainside
Apr 9, 2010 07:24 AM
philep_cb7_91
Feb 21, 2010 11:28 AM
vtec94civic
Aug 9, 2005 03:35 PM
QWKPHKR
Oct 8, 2002 06:37 PM
